Author Topic: Blinkers always on?  (Read 1053 times)
Offline CBcafeJunkie
  • 75 CB750F
Blinkers always on?
« on: November 30, 2013, 08:03:15 AM »
I rewired my bike recently and i am having a bear of a time figuring out why both led turn signals stay on i don't have a winker relay hooked up as of now though either. its wired stock as far as blinkers go.
Offline bjbuchanan
Re: Blinkers always on?
« Reply #1 on: November 30, 2013, 08:17:23 AM »
If you don't have a blinker relay it won't blink...
Also there are a lot of threads covering this but basically you gotta go get an EP35(?) electronic flasher. Three prong style and you use the extra ground conveniently dangling under the left hand side cover
« Reply #2 on: November 30, 2013, 10:15:40 AM »
You need a relay for them to blink.
You'll need an electronic relay for LEDs to blink.
The current draw for leds is not sufficient to activate the standard relay.
Also, be sure your batter is in good order.  A weak battery will also give the same result.
  • 75 CB750F
« Reply #3 on: November 30, 2013, 11:43:02 PM »
I've got a good battery and an ep34 winkler relay for led/2-6 lamps hooked this up but no results
I have both orange and both blue hooked up the their respective blinkers
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #4 on: December 01, 2013, 05:39:31 PM »
I believe K3's and up have running light blinkers that come on with the headlight. At least that's what mine do...
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Sprocket75
« Reply #5 on: December 02, 2013, 11:23:18 AM »
I had a similar issue while rewiring mine. Having never owned a CB550 (much less any motorcycle) I was baffled as to why my front turn signals came on and stayed on...lol. I even posted a thread on this site asking why they did this. DOH! Then someone explained to me that they are running lights. OOOOOHHHHHH! I felt like a real bonehead then. Suffice to say, they work great. :) Now, ask me about the rear parking light and ignition switch...  ::)
..."Always two there are, no more, no less. A master and an apprentice"... YODA
1975 Honda CB550K
Offline bjatwood
  • 1973 CB750-K3
« Reply #6 on: December 03, 2013, 05:29:46 AM »
 8) hey we've all been down the Duh! road. I think it's the most scenic...LOL
Brian
#24193
