Author Topic: 500 Trees  (Read 970 times)
jlrichardson
500 Trees
« on: September 03, 2006, 01:30:20 PM »
does anyone know if the bottom trees (and post) from a '76 500T fit on a '72 500??
Re: 500 Trees
« Reply #1 on: September 03, 2006, 02:57:31 PM »
Well it may fit, but the offset is greater with the 500T, (distance from steering axis to fork center)  The width (fork center to fork center) is the same. I wouldn't make the swap, it'll throw the steering geometry way out. Another 500 four steering stem can be found easily if you need it.
jlrichardson
Re: 500 Trees
« Reply #2 on: September 03, 2006, 03:25:32 PM »
yah i need it. the threads at the top of the pipe are stripped and i cannot find anyone around my city that can do a metric thread that big.
Re: 500 Trees
« Reply #3 on: September 03, 2006, 04:32:22 PM »
I can only find one here at the moment and better keep it, but if you post in the parts wanted forum I'm sure one will pop-up.
