Author Topic: 630 to 530 chain conversion  (Read 7422 times)
Offline hazardus320
« on: January 03, 2014, 08:04:07 AM »
I am looking to use a 530 chain on my '78.  I know the '77 and '78 came stock with the 630, and the '76 came stock with the 530 (and their corresponding sprockets as well).
Does anyone know if I could just order up some of the '76 stock sprockets and bolt them up? Or if there is any issues with doing so?  Thanks in advance!
Sent from my SM-N900T using Tapatalk
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: 630 to 530 chain conversion
« Reply #1 on: January 03, 2014, 10:01:28 AM »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline hazardus320
« Reply #2 on: January 03, 2014, 10:10:38 AM »
Thank you sir, sorry my searching skills were subpar!
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #3 on: January 07, 2014, 06:47:31 AM »
Just to update that thread - that was almost three years ago. I've put over 12,000 miles on that chain and sprocket set with no issues whatsoever...other than the lousy fit of the front sprocket on the shaft. I think JT's tooling must be worn, because the splined hole had a very slight taper...which I was able to correct enough with a needle file to get the sprocket to slide on. Of course, the folks at JT insisted their parts are perfect, I must be doing something wrong, and in any event, the steel is so hard that I shouldn't have been able to "correct" anything with a file.  ::)
Just FYI, Parts Unlimited sells a sprocket which is a direct replacement for the original '76 750A Honda part #. Their part number is K22-2519. One on eBay right now.
http://www.ebay.com/itm/FRONT-SPROCKET-HONDA-530-Chain-17T-K222519-23801-300-010-L4-/370679919415
Part # = 23801-300-010
Part Description = SPROCKET (17T) - (replaces 23801-300-000)
Model Count = 16
CB500 1971 500 500 Four Street
CB500-K1 1972 500 500 Four Street
CB500-K2 1973 500 500 Four Street
CB550F-K2 1975 550 550 Super Sport Street
CB550F-K3 1976 550 550 Super Sport Street
CB550F-K4 1977 550 550 Super Sport Street
CB550-K0 1974 550 550 Four Street
CB550-K1 1975 550 550 Four Street
CB550-K2 1976 550 550 Four Street
CB550-K3 1977 550 550 Four Street
CB550-K4 1978 550 550 Four Street
CB750A-76 1976 750 CB750A Hondamatic Street
CB750F-K5 1975 750 750 Super Sport Street
CB750F-K6 1976 750 750 Super Sport Street
CB750K 1969 750 750 Four Street
CB750-K0 1970 750 750 Four Street
« Last Edit: January 07, 2014, 07:02:02 AM by chickenman_26 »
MCN DTF
« Reply #4 on: January 07, 2014, 10:14:34 AM »
Hope this helps. Copy of email.
Yes,
Part number 517-17
Cost $24.99
Give me a call if you would like to order.
Thank you,
DeeDee Sarao
Office Manager
Sprocket Specialists
(530) 533-0802
(530) 533-0663 Fax
deedee@sprocketspecialists.com
-----Original Message-----
From: Jerry Griffin [mailto:geraldjgriffin@gmail.com]
Sent: Sunday, September 29, 2013 10:25 PM
To: info@sprocketspecialists.com
Subject: General Question
Did you ever get the 630 to 530 conversion front sprocket 17 tooth for the 77/78 Honda CB750K back in stock?
Offline limerence
« Reply #5 on: June 18, 2014, 07:00:23 PM »
I have a 78 CB750A. I just bought the Parts Unlimited sprocket that chickenman suggested.
Any guidance on what size 530 chain is needed?
Thanks,
John
Offline dave the welder
  • dave the welder
« Reply #6 on: June 18, 2014, 08:05:29 PM »
I used the sun star conversion kit for my 77 750A 2 years ago.it came with both gears and chain everything bolted right up,no shortening chain so for everything is good
don't buy it build it
Offline limerence
« Reply #7 on: June 18, 2014, 08:51:44 PM »
Hmmm... would you happen to have a link to the kit? I cant find it on sun stars site.
I also bought the parts unlimited front sprocket already so will have to piece together the kit. Looking at the kit would help me to know what else I need to buy.
Thanks,
John
  • dave the welder
« Reply #8 on: June 19, 2014, 04:37:16 AM »
ebay Honda750A parts
« Reply #9 on: June 19, 2014, 02:53:18 PM »
Thanks,
John
John,
Check your private messages
MCN DTF
Offline limerence
« Reply #10 on: June 19, 2014, 06:07:42 PM »
Thanks Stu.
Parts are ordered!
Offline hazardus320
« Reply #11 on: December 18, 2014, 12:34:27 PM »
I have the K model carbs as well as a cyclex cam in my bike right now, i took it out for a quick spin to test the rpm as im cruising around and she seems a bit high.  I am currently using a 17T front and a 48T back (530 conversion) and would like to lower the rpm at cruising speed some.  My options from Sunstar, that i see are (for the back):  38T, 40T, 43T, 45T .
Do you guys have any recommendations for what size i should lower to to achieve my goal of a lower RPM at ~60mph?  The more detail as to why, the better!  Thanks in advance!
Offline hazardus320
« Reply #12 on: December 18, 2014, 01:02:04 PM »
I would provide an RPM if I had a tach, but unfortunately I do not.  I am using the standard tire size for the '78 750a.  Unsure of RPM I am seeking to be exact.  All I know is it currently is wound more up than I would like at that speed.
Offline hazardus320
« Reply #13 on: December 22, 2014, 07:40:44 AM »
I just bought a 43T for the rear.  Once spring hits I will let you guys know how she goes with it installed.  Damn MN winters!  At least I have a heated garage to tinker in! :)
Sent from my SM-N910T using Tapatalk
Offline nixon
« Reply #14 on: July 19, 2015, 06:19:02 PM »
definitely liking the 17-43. up to 80km/hr in 1st..
530 conversion from sunstar fit no issues whatsovver. Its rivet not clip link though so get the tool before your order ! nothing worse than a rebuilt rear end with just a link stopping a test ride..trust me
cb750a 77, cbr900rr 93 with auto clutch
Riding tip " turn in late, feeling great.  Turn in early,  feeling squirrely "
