Author Topic: '78 CB750F Regulator  (Read 627 times)
Offline SurfinBird
« on: January 05, 2014, 10:19:54 AM »
Been gone a while and haven't touched the bike for bit. I just got back to getting it rideable again. I was having a charging issue with too much at the battery (15+, gel battery). I adjusted the regulator, but it still wasn't charging. I confirmed my battery is bad (guessing I fried it with it being too high at the battery while running). I went to fiddle with the regulator and found that no matter what i did the volts stayed at 12.1 at the battery, even if the screw was was all the way out or all the way in. Do I need to replace the regulator? I should note I was using the bad battery to test.
Re: '78 CB750F Regulator
« Reply #1 on: January 05, 2014, 11:23:48 AM »
Here is a link to an easy diagnostic check.
They also sell great reg/rec units.
http://www.oregonmotorcycleparts.com/FAQ.html
