Author Topic: 750K Carb Reassembly  (Read 674 times)
Offline timbo750
« on: January 08, 2014, 02:46:40 AM »
I have finally nearly finished cleaning the all the carb parts and have the rebuild kits but as they wont be fitted and used for while was wondering if the seals etc will dry out if the carbs sit on the shelf for what could easily be several months?
Re: 750K Carb Reassembly
« Reply #1 on: January 08, 2014, 04:11:18 AM »
Seals will be fine few month for sure.
I wrap my carbs after cleaning in Stretchtight against mainly mud daubers and shelf them.
« Reply #2 on: January 08, 2014, 05:50:16 AM »
Are you using aftermarket jets, needles and other brass bits ? Don't toss the stock stuff, you may like it better.
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: January 08, 2014, 06:44:04 AM »
When I store carbs, I usually squirt a little Seafoam (you can get it in a spray can) in them and put them in one of those large ziplock bags.
Offline timbo750
« Reply #4 on: January 08, 2014, 02:23:16 PM »
Yeah the kits are after market, I had read somewhere to keep the originals. The engine is getting an 836 kit and was actually expecting to have to increase the jet sizes.
Seafoam, is that anything like WD40? I like the Ziplock bag idea.
« Reply #5 on: January 08, 2014, 02:27:50 PM »
seafoam is a fuel, and oil treatment.
it allows water to be burned with the fuel, and aids in removing and preventing fuel varnish.
