I am having the same issue, once again.... What is a good way to clean the connections up/ would it be best just to replace them, the connections for the main fuse are noticeable darker and look more beat up then the others and the soldering looks worse as well. Idk if this has something to do with it.
I also noticed someone said something above about replacing the holder to one that works with the modern square fuses, is that easily done?
