Author Topic: 550 vs. 750 Tank Badges  (Read 656 times)
Offline PGF550F
« on: January 29, 2014, 01:59:52 PM »
Does anyone know if tank badges from a 750 will work on a 550 tank? This is not going for a full blown resto, so using more common(readily available) parts will save me some headaches. When I got the bike the tank badges were gone and the area filled with bondo and painted over. Slowly breathing some new life into this bike and I certainly prefer the look of badges rather than going with decals. Anyone know if they fit? The badges I am thinking of have the 2 metal pins on the back that are secured by small clips to the tank.
Offline greenjeans
  • 1972 CB750K2
Re: 550 vs. 750 Tank Badges
« Reply #1 on: January 29, 2014, 02:10:56 PM »
If the tank has filler where the badges go, it won't matter.  You can just trim the tabs off the backside and use some good double-sided tape.
I don't know for sure, but I'd guess that the 550 badges would be a few millimeters smaller.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: January 29, 2014, 02:31:17 PM »
« Last Edit: January 29, 2014, 02:40:24 PM by LesterPiglet »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: January 29, 2014, 03:13:10 PM »
It depends on the years and models. Check your microfiche for part numbers to be sure. I think the 76 550K emblems fit a earlier model 750K or something like that.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline PGF550F
« Reply #4 on: January 29, 2014, 05:15:54 PM »
Thanks for the replies. I got all the old cracking paint and bondo off the tank and was hoping to pick up some cheap used badges off eBay to restore to presentable shape. I'm going to be repainting the tank first and thought it would be best to use the stock attachment system. I'll have to check into the distance between posts to see if they are the same.
11.3 cm or 4.5 inches from center to center on the tank mounting tab holes.
« Last Edit: January 30, 2014, 01:20:03 PM by PGF550F »
