Author Topic: float pins stuck hard  (Read 9981 times)
Re: float pins stuck hard
« Reply #25 on: February 09, 2018, 08:36:57 PM »
Just saw (and deleted) a new float pin remover tool day or so ago.
Offline MoMo
  • Ride like you're invisible
« Reply #26 on: February 09, 2018, 09:03:59 PM »
Good idea on the heat shield,  I have a couple pins stuck in my Katana that will need heat to remove...Larry
Offline Gordo
« Reply #27 on: February 09, 2018, 11:10:19 PM »
Heat,carb cleaner and a spring loaded centre punch, make sure to brace the float tower when using the punch as the tower will snap easily.
