Author Topic: cb500 clutch cable question  (Read 1286 times)
paul_D
« on: March 01, 2014, 08:42:38 PM »
What is the difference in the lengths of clutch cables for the cb500
22870-323-010 (USA)   vs.   22870-323-620 (Euro)
I have the shorter european bars on my bike but only the USA cable is available here. Would there be any problems using it ?
Offline mjstone
  • I'm definitly not a
Re: cb500 clutch cable question
« Reply #1 on: March 02, 2014, 06:05:15 AM »
I don't think will make that much difference.  Make sure when your routing the cable you don't kink it.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
paul_D
« Reply #2 on: March 08, 2014, 09:33:32 AM »
New Honda clutch cable in, proper routing around steering tube, through frame and between 1&2 inlets, works beautifully.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: March 08, 2014, 09:38:17 AM »
Lucky you. I got a cable for my Euro barred 550, must be US spec. Cable needs to go up over the clocks.
paul_D
« Reply #4 on: March 08, 2014, 09:48:30 AM »
Could be because the 550 has different clutch/location.
After looking closer last night. The euro bars dont have the knurlind in the bar clamp. I'm thinking theyre aftermarket now.
« Reply #5 on: March 08, 2014, 08:39:26 PM »
the 500 and 550 clutch cables use a different free length,you cant use a 500 cable on a 550 and visa versa!
paul_D
« Reply #6 on: March 08, 2014, 08:40:56 PM »
Right. I got the 500 cable on my 500
