Author Topic: 1976 honda 750f1  (Read 1010 times)
Offline Gunga
1976 honda 750f1
« on: March 06, 2014, 08:07:23 PM »
Anyone have any ideas why my speedometer shows 10mph faster than my actual speed.  I also am wondering if anyone out there has a left sidecover with emblem for a 76 750f1.  I live in MN
Offline krusty
Re: 1976 honda 750f1
« Reply #1 on: March 06, 2014, 08:15:36 PM »
How have you determined that it is out?
Checked against a GPS have we?
Incorrect tyre size??
Incorrect speedo drive?
Or dodgy speedometer?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline Gunga
« Reply #2 on: March 06, 2014, 08:33:17 PM »
Radar sign that posts my speed is how I checked my speed.  I also get passed on the highway by everyone when following the speedo.  My tires are the correct size and my speedo is original.  Something could be wrong with it I suppose.
Offline Steve F
« Reply #3 on: March 07, 2014, 08:20:44 PM »
They're supposed to read faster than actual speed, that's the way Honda designed them, but 10 over is a bit much.  There are people out ther that can re calibrate them but it's NOT cheap.  It involves cutting them apart to open them up for service.  I would suggest you find a replacement and try it.
Oh, and those radar signs aren't that reliable.  Buy or borrow a GPS and see what your speed is with one of those.
Offline Hon3ybadger
  • Someday it will run...
« Reply #4 on: March 24, 2014, 09:20:03 AM »
Yes GPS is the best route. Unless you drive in tunnels. The quick and dirty trick I do is find a newer Honda civic and look through the driver side window at the giant digital speedo they have. Match your speed with them and compare gauges. I found mine wiggles three to six mph faster than their speedo says. And its tested against many civics. Tire size is 100/90/19
« Reply #5 on: March 24, 2014, 09:48:28 AM »
does the speedo needle rest against the 'zero' post on the face, or does it hang up a bit higher?
someone might have been inside the gauge and attached the needle in the wrong spot.
Markcb750
« Reply #6 on: March 24, 2014, 05:15:09 PM »
Showing higher than actual is a common condition, sometimes cleaning & lubing drive cable will help, but not a lot.
Mine reads 52 at actual 45.
Until I 'calibrated" it people were passing me all the time.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: March 28, 2014, 09:33:34 AM »
A lot of people put bigger tires than stock, me included. that will throw the final drive ratio off a bit.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
