Author Topic: Bolt at Bottom of Forks  (Read 2733 times)
Tiek101
« on: September 12, 2006, 01:24:28 PM »
I need some help.  I am trying to disassemble my fork (750K5) and the bolt on the bottom (damper rod bolt?) will not come out.  It was tight at first and I figured it was coming out but now it just turns and turns.  I cannot get the fork tube out of the lower leg.  ...any suggestions?  Thanks
Offline Gordon
  • 750K1, 550K2
Re: Bolt at Bottom of Forks
« Reply #1 on: September 12, 2006, 01:34:55 PM »
Put the spring and spring retaining bolt back in the top of the fork and try again.  Sometimes this will put enough pressure on the works to keep it from spinning while removing the lower bolt.  Others have suggested inserting a wood dowel into the top fork tube to acheive the same effect.  I've used an air-powered impact driver before with good results due to the speed it turns.
Tiek101
« Reply #2 on: September 12, 2006, 01:41:04 PM »
Thanks!  I'll give it a try.
Offline putnaja1
  • '77 CB 550k -Was gonna cafe, but looks cool stock!
    • Jason's Wacky Website
« Reply #3 on: September 12, 2006, 01:58:22 PM »
I'm getting ready to tackle my forks as well..  When putting this bolt back in- do you just put the springs and caps back on, and use like a 3/8" impact gun to tighten the bolt?  Or the broomstick trick, and tighten to a specific torque?
Jason
Play Pinball!
My Gallery!
"The world is divided into people who do things, people who get the credit and people who continually criticize.  Try, if you can, to belong to the first class of people.  There's far less competition"
« Reply #4 on: September 12, 2006, 02:02:54 PM »
You need the rounded end of a broom handle tapped ever so gently into the inner tube. I spun the thing till it was a blur. Tapped the broom handle in and it was out in seconds. You also use the handle when you tighten it up.
Offline Ernie
  • Dead again,could I get a
« Reply #5 on: September 12, 2006, 03:15:15 PM »
its never a good idea to tighten any nuts or bolts with an impact gun, pneumatic or electric ;)
Its all happening !
my 1978 CB550K.......>>>
http://gallery.sohc4.net/main.php?g2_itemId=4440
Tiek101
« Reply #6 on: September 12, 2006, 03:21:21 PM »
I put the spring back in and it worked like a charm.  Thanks for the advice.  Looks like I need new fork tubes, they are pitted pretty bad.
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: September 12, 2006, 03:56:02 PM »
Good point, and thanks for saying it! ;D
Offline jaknight
  • ....Round Town Ride......
« Reply #8 on: September 12, 2006, 05:48:36 PM »
     I have recently rebuilt my front forks.  I removed the complete fork/tube assembly and held the tube in a vise with leather padding.
     The bottom bolt came out easily by using an allen wrench by hand.  I also would never install/torque with a drill motor or pneumatic driver of any kind.  It is relatively easy by hand with an allen wrench.  With proper setup in a torque wrench, you can go for exact settings if you want.  Really tight by hand, it ain't gonna go anywhere.
     It's a fairly simple deal.  Make sure you have the new seals proper side up for installation.  Oil them before you install.  In fact, just be sure and oil up everything as you reassemble........ ;) ;)
     ~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline putnaja1
« Reply #9 on: September 12, 2006, 08:11:27 PM »
Yes- You are right..   ;D  Of course, there are things you can get away with..
I honestly think you can get an accurate feel for air powered impact guns.  I used to get away with tightening with my 3/8" impact gun (air powered), because it wasn't super strong to begin with, and you can adjust the strength too..  I'd always start bolts by hand, then give it a quick blast of air just to zip the bolt all the way in (but not to tighten), then I teeny tiny blip (maybe two or three impact hammer hits) to tighten.  This method was varied by application too..  I was able to consistenty tighten things like the pump into an automatic transimission, valve covers, etc. after I "learned"..  I rung off a lot of bolts before I learned!  :-)
It's been a lot of years though- probably best I am no longer in the shops, and I don't have a home compressor! 8)
Play Pinball!
My Gallery!
Offline dpen
« Reply #10 on: September 13, 2006, 05:17:03 AM »
I too have found that you can accurately tighten things with a rattle gun.
Of course it took me the first five years of my trade to almost perfect it.
If you ain't a top mechanic - don't risk it.
Offline dusterdude
« Reply #11 on: September 13, 2006, 05:37:52 AM »
huh?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
750k5
« Reply #12 on: September 13, 2006, 05:59:58 AM »
The correct method to remove the allen head is to use your impact tool.  Get an allen head to fit it, and fully assembled turn the fork over, and give the impact a rap with the hammer, and it will come loose..
