SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
four smoking guns
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: four smoking guns (Read 2744 times)
viking
Guest
four smoking guns
on:
May 22, 2005, 05:48:59 AM »
hi, i have a 73 cb500 f, it starts easy, idles and runs good, but after som hard riding it starts to smoke badly,(grey/blueish), but it stil runs good, anyone have an idea of what to look for? i have only had the bike for 3weeks.
Logged
Gordon
Global Moderator
Really Old Timer ...
750K1, 550K2
Re: four smoking guns
Reply #1 on:
May 22, 2005, 06:10:04 AM »
Bluish smoke is an indication of burning oil. Could be any number of things like worn/stuck rings, or bad valve seals. Is it definitely a blue smoke? If not it may just be running rich. Check the plugs. They're probably black either way, but are the oily black or sooty black?
Logged
viking
Guest
Reply #2 on:
May 22, 2005, 06:17:10 AM »
the plugs are more like sooty black,and the smoking started on one pipe , but is now on all four,it smells like a two stroke
Logged
bryanj
CB500 Number 1000036
Reply #3 on:
May 22, 2005, 08:04:24 AM »
Almost certainly valve stem seals with a secondary of stuck rings. At least the top end comes off in the frame on these
Logged
viking
Guest
Reply #4 on:
May 22, 2005, 09:53:55 AM »
thanks guys, guess its up to me and the spanners now
as a former BSA ovner im used to that
Logged
TwoTired
Reply #5 on:
May 22, 2005, 10:45:48 AM »
Blue exhaust smoke is indeed an indication of oil burning.
Are you using any fuel additive that could contribute to this?
Often oil burners will show the symptoms on the spark plugs. This site:
http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
shows a plug with oil deposits. But, I've seen examples where the deposits were much more bilowy.
Oil can get into the combustion chambers via the rings or past the valve guide. You can get an idea of which to focus on by doing a compression check on the hot engine. Take out all the plugs and record the highest compression reading you can get on each cylinder while operating the kick starter. Now, put a half teaspoon of oil into each chamber and repeat the procedure for a second set of numbers. Now analyze the data. All the numbers from each test suite should be within 10% of each other across the cylinders. If the oil has helped seal the rings, then the second set of numbers will be higher than the first set. If the added oil didn't make a compression difference, then the blue smoke can be oil getting in past the valve guides. In worn out engines, both problems can occur.
Heads up putting the cam cover back on: back way out all the tappet adjusters so they won't catch on the valve stem and bend valves during reassembly.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
four smoking guns
