The pilot screws shouldn't radically change the idle, they don't adjust your idle. The main adjustment knob (the big one) on the carb rack is what adjusts it.
If you have no effect from them at all it could be dirty carbs. Set them to 1 turn out and leave them unless you want to do fine tuning. 1 turn will be close enough to do any other work like syncs
