Author Topic: Special top end work  (Read 1795 times)
Offline joeb
« on: September 16, 2006, 06:53:36 AM »
Well last Saturday Sean Condon and myself replaced the keepers and retainers on my 750.  The procedure was pretty interesting considering we never pulled the head and I thought I would share it with you . We used compressed air and a valve tool that connects to the valve springs, so if you need to put in new springs ,retainers ,keepers, or seals and do not want to pull the head this is the way to go. I used the fitting off my compression tester and a quick release for the air line and  the valve spring compressor I purchased from JC whitney for $29.00.  All we removed was the rocker arm assemblies, no need to disturb the cam itself.  WEll thats about it.
Re: Special top end work
« Reply #1 on: September 16, 2006, 07:15:30 AM »
 Now go beat the snot out of that thing Joe. ;)
Offline joeb
« Reply #2 on: September 16, 2006, 07:18:53 AM »
Will have it together hopefully today , just need to put on the exhaust and the chain and I should be ready to go.  ;D
Offline joeb
« Reply #3 on: September 16, 2006, 04:17:11 PM »
Its alive and kicking test drive went well.  ran it up to about 8 grand in third gear ,if I only had wings. :o
« Reply #4 on: September 16, 2006, 05:06:36 PM »
Good....I don't have to worry about you dropping a valve now. ;) ;D
« Reply #5 on: September 16, 2006, 05:22:07 PM »
PS....nice work both you and Sean. ;D
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #6 on: September 16, 2006, 06:09:23 PM »
I've heard somewhere (can't remember where) that you can thread thin-ish rope down the sparkplug hole into the cylinder to 'fill' the combustion chamber and therefore keep the valves closed.... Anyone else have experience or knowledge of that?
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline scondon
  • Mmmm......tasty bugs
« Reply #7 on: September 16, 2006, 06:47:54 PM »
    At first I didn't really see the difference between how the '78 keepers and the '76 & under keepers held the Kibblewhite valve stem. I mean I could see that the '78 keepers have a raised ridge halfway down the mating surface but they appeared to hold the valve stem just the same. It wasn't until we had half of the keepers/retainers swapped out that Joe noticed how much lower the valve stem sat in the retainers with the '78 keepers. Turns out the only thing holding the keepers to the stem was the rounded ridges halfway down the keepers, YIKES :D :D :D :D :D :D :D
   Don't know if the 77-78 750K has the same keepers as 77-78 750F but I assume if your swapping in Kibblewhite valves in these later motors make sure to swap the keepers/retainers as well. Thanks a mil. for pointing this out Mike :)
  And Joe, good work my man. Glad your up and running with a good bit of dry riding season left.
racing33
« Reply #8 on: September 16, 2006, 09:12:53 PM »
 I use the rope trick to this day. The rope works good and it will not hurt anything.
Bruce
« Reply #9 on: September 17, 2006, 05:49:50 AM »
   Yep....a disaster waiting to happen.
Offline nickjtc
« Reply #10 on: September 17, 2006, 09:50:00 AM »
Bruce
Hey Bruce. Would you care to share your procedure?
1977 Suzuki GS750
