Author Topic: best and cheapest way to get engine ready for paint at home  (Read 5254 times)
Offline reddyvv
Re: best and cheapest way to get engine ready for paint at home
« Reply #25 on: May 14, 2014, 10:00:50 AM »
After degreasing spray the engine down with Aircraft Stripper. It will lift up all the paint and you can then hose the remnants off.
Offline Bru-tom
« Reply #26 on: May 14, 2014, 10:24:43 AM »
"Perfect" accurately describes your bike, Bru-tom. Remember. Nobody likes a show-off ;)
thanks i think. ;) nah dude, just showing what normal automotive paint can do.
how do others keep their high heat painted motors from being harmed by solvents?
Offline Stoli
« Reply #27 on: May 14, 2014, 10:27:15 AM »
Only the fins are sanded on my engine.  Sun reflection make it look like the cover lines and letters are sanded.  I left them black.
I sanded it a few times during cleaning so the ends were flat and all shaped nice.
Med emery paper to shape, and then 800 wet to finish.
This made light work of paint removal once cured.
I figured there'd be paint chipping if you were taking the paint off AND creating the flat on the fin edge.....
Got it. Thanks. Must be the lighting in the pic but it looks like the "SOHC" on the valve cover is bare aluminum as well.
** Sorry for the hijack. We are talking about engine paint though so sort of on topic.  ;)
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline Stoli
« Reply #28 on: May 14, 2014, 10:30:22 AM »
I used duplicolor engine paint on my first build and it holds up decent to gas. Have had a few drops come down from the carbs with no ill effects.
My Project Threads:
Offline Bru-tom
« Reply #29 on: May 14, 2014, 10:51:04 AM »
thats great! is it high heat or dedicated engine enamel though?
Offline Bru-tom
« Reply #30 on: May 14, 2014, 10:59:00 AM »
thanks i think. ;)
It was totally meant as a compliment. And well deserved too.
hahaha thanks brother, i didnt mean it to look like i was showing off though.
back on topic, nice thing about the 2k paint is, you can get any colour you want, any amount of metallic or matting agents mixed in to give you the exact look you are after. resists heat very well, i mean, we had a close to 40deg Celsius day in summer and i rode in quite congested traffic for quote a while and no problems with the paint thus far. only downside is, is that a compressor and spray gun are required.
Offline Stoli
« Reply #31 on: May 14, 2014, 11:36:55 AM »
Engine enamel. Rated to 500 degrees.
My Project Threads:
« Reply #32 on: May 14, 2014, 11:56:21 AM »
+1....and a light wipe of kerosene doesn't bother it.  Simple green and the like are fine, too.
Acetone on the other hand would wash it right off  :o
Offline Grinnin
« Reply #33 on: April 06, 2015, 04:22:45 AM »
I'm not looking for cheap, but this looks like the most recent near match for my question.
But my question is more about what to paint or not paint on the 750 K5 engine.  Do I paint the shift-linkage cover?  The engine has been painted black.  It was either badly or many hard miles ago.  The cases are entirely apart and I'll spend most of April prepping for paint.
I always put boot rub marks on paint. If I use high-temp paint or engine paint on the cases, I will end up with boot marks beside the shift lever.  THAT case is currently a stock clear-coated piece and looks OK.  I'll be using a stock clear-coated valve cover too.  The right boot won't leave rub marks on the engine at all since the outer sheet-metal covers are chrome.
I think the engine looks weird with mostly black block, chrome covers in 3 corners, and a clear-coated aluminum cover at the 4th corner.  But painting that cover is asking for a ratty look down the road.
What do others do to have a wear-resistant shift linkage cover?
Thanks.
Offline Lostboy Steve
« Reply #34 on: April 06, 2015, 08:10:04 AM »
be careful of high heat paint, if you mess fuel on it, it will lift and melt off. I use 2 pack automotive paint and a very good epoxy 2 pack etch primer. been 2000km so far and its perfect still! ;)
Can we talk abotu that airbox real quick? What is it, besides spectacular?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Phinn
  • Subversive
« Reply #35 on: April 06, 2015, 08:54:46 AM »
Is high temp paint needed on the 4 engine covers, or just the case/cylinders/head/valve cover?
1978 CB750K -- "Mouse," a former basket case, resurrected
Offline mrfish2
  • I might be a
« Reply #36 on: April 06, 2015, 03:58:35 PM »
That's exactly what I was thinking. That carbon fiber is sexy.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #37 on: April 10, 2015, 07:08:39 AM »
I was wondering if that air filter element is just metal like a Puch moped. lol Seriously is that airbox hand laid carbon fiber?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline jamesbekman
« Reply #38 on: April 10, 2015, 08:49:36 AM »
Never underestimate the power of an angle grinder and a brass wire wheel...  Cheap and easy and works like a charm...  Same with stripping down the frame.
