Author Topic: diagnosing charging system 1978 cb750k sohc  (Read 3224 times)
Offline JR.
« on: May 13, 2014, 11:12:09 PM »
I am new to this site hopefully I can find some good information here.   My Motorcycle will not charge the Battery Voltage at the Batt cables does not change when revved up.
I have fixed up a 1978 CB750K8 SOHC, I am using a clymers manual  I have tested the rectifier the 6 diodes are good according to what I have learned about testing it. I have been told that the voltage regulator is mechanical and there really is not a way to test it but I have adjusted it according to the manual.  The field coil tests at 8.2 Ohms no short to ground, the manual says it should be at 7.2 does that make it bad, some have said no. The stator tested around .555 Ohms and no short to ground. I have not been able to test the rotor slip rings because that part is still on the bike I will be taking it off tomorrow to test the rings i have researched what it should test at and from what I have found it should be between 4.2- 5.0 no higher. Are there brushes to this assembly and should there have been oil in the Left side cover where all of this is? I have been told yes there should be. The battery is fully charged.  Can anyone confirm or correct any of this? If you can add  anything to my knowledge or if anything that I have learned is incorrect I would be happy to learn from you. The bike is ready to ride besides this. Thank You.
Offline JR.
Re: diagnosing charging system 1978 cb750k sohc
« Reply #1 on: May 14, 2014, 05:57:58 AM »
I just discovered that the rotor is just a hunk of iron and not magnetized is this correct?
Offline Grinnin
« Reply #2 on: May 14, 2014, 08:04:45 AM »
The rotor is non-magnetic when not turning.
There are 2 stationary parts:  the field coil is an electromagnet that is energized (magnetized) by the voltage regulator.  The other "stator" is the charging coils.
At startup and low RPM, the regulator will provide full voltage to the field coil which causes a strong magnetic field.  The rotor swirls that magnetic field toward the charging coils.  As the voltage rises the regulator reduces the voltage to the field coil and thus reduces the strength of the magnetic field and thus reduces the voltage.
You need a battery to get it all started since there are no permanently magnetized parts in the system.
There are no slip rings.
Offline Airborne 82nd
« Reply #3 on: May 14, 2014, 08:17:49 AM »
You should be able to find the issue with this. It is in the FAQ.
Three phase charging system inspection and maintenance for all pre 79 SHOC4 moto
« Reply #1 on: May 17, 2005, 01:47:44 AM »
cb750_chris: This is how a trained Honda mechanic would service your bike if you took it in and claimed it had a charging problem.  Rather I should say trained and interested in doing the job right on an old bike.
Three phase charging system inspection and maintenance for all pre 79 SHOC4 motorcycles.
I.   Initial inspection.
A.   Charging system fuse check
1.   If open replace.
2.   If shorts again search for short circuit.
II.   Full load test.  (Determines battery condition).
A.   Turn ignition and high beam on while bike is not running.
B.   Test battery voltage.
C.   Voltage bellow 10.5V means battery needs service.
III.   Charging the battery.
A.   If specific gravity of any cell is less than 1.230 battery has low charge.
B.   If sediments in battery are touching bottom of any plates replace the battery.
C.   If specific gravity varies more than .050 then replace battery.
D.   If fluid level is low add distilled water only.  Don’t add too much as level may rise even more while charging.
E.   Charge the batter at no more than 10 percent of its amp hour rating.
F.   If battery temp. is more than 113 degrees F allow it to cool then resume charging.
G.   If specific gravity of any cell will not charge above 1.230 then replace the battery.
H.   Put the fully charge battery back in the bike and do the full load test again.  A running RPM test cannot be done unless you have a fully charged battery.  If the voltage is above 12V then you can do the RPM test.
I.   Start the engine and lock the throttle when the RPM is above 4000.  If the voltage is between 14V and 15V the system is fine and the battery was to blame.  If not you have more work to do.
IV.   If @ 4000 RPM the voltage was bellow 14V…
A.   Check for problems.
1.   Corroded, loose, or mismatched wires.  I.e. orange and green wire plugged in to each other.
2.   Modified or non-stock systems.
3.   Visibly damaged wire insulation.
B.   Do a system analysis resistance test.
*.  NOTE 0 resistance = good wire.
*.  NOTE infinite resistance while grounded to frame = good insulation.  Coils will automatically have resistance.
C.   Resistance testing of regulator wires.
1.   While the bike is not running disconnect (-) battery lead and Black regulator wire.  Check for 0 resistance between (-) battery wire and Black regulator wire.
2.   Disconnect all regulator leads.
a.   Test for resistance between I and F poles.  0 resistance is good.  If greater than 0 clean the regulator points.
b.   Test for resistance between the white wire and ground.  Resistance between 4 and 8 ohms means the field coil is good.
V.   Testing the stator yellow leads.
A.   Test wires 1 and 2, 1 and 3, 3 and 2 for ohm readings.  Less than 1 ohm means the circuit is good.  Greater than 1 ohm means poor connection.  Infinite resistance means that the coil has an open circuit or possibly a bad lead.
B.   NOTE.  For GL1000 you need to disconnect/remove the permanent magnet rotor before continuing.  Set tester to insulation resistance and calibrate it to 0 to perform a wire insulation test on the stator.  Ground the negative test lead and touch the other lead to each of the three stator wires.  If the resistance is infinite then the coil is ok.  If not then the coil is shorted to ground.
C.   Test the three stator wires in the harness of the motorcycle.  First disconnect the rectifier.  Set the tester to resistance.  0 resistance means all three wires are fine.  Greater than 0 means the wire is bad.
D.   Check the wires for bad insulation.  Connect the black tester lead to ground.  Each wire should have infinite resistance.  Greater than infinite resistance means the wire has bad insulation.
VI.   Check the five leads on the rectifier.
A.   To perform a forward bias test first connect the red tester lead to the green ground lead.
B.   With the black tester lead test all three yellow wires.
C.   Resistance must fall between 5 and 40 ohms.
D.   To perform a reverse bias test connect the black tester lead to the green ground lead.
E.   With the red tester lead test all three yellow wire.
F.   Resistance must be greater than 2000 ohms.
G.   Connect the black tester wire to the red and white rectifier lead.
H.   With the red test lead test all three yellow wires.
I.   All three must have between 5 and 40 ohms.
J.   Connect the red test wire to the red and white rectifier lead.
K.   Test all three yellow wires with the black tester lead.
L.   Resistance must be greater than 2000 ohms.
VII.   Testing the harness plugs and leads.
A.   Test each of the plug wires in the circuit for o resistance.
B.   While the battery and rectifier are disconnected test the red and white harness rectifier wire to the (+) battery lead for 0 resistance.
VIII.   Regulator bench test.
A.   Remove regulator cover.
B.   First check the core gap to be sure it is between .6 and 1mm.
C.   Next check the points gap to be sure it is between .3 and .6mm.
D.   Clean the points with contact cleaner.
E.   Note the 350F points gap is not adjustable.
F.   Test the regulator leads by first placing paper on both sides of the points contacts.
G.   Test resistance between I and F, then I and E terminals.  Check you manual for model specific resistance readings.
H.   Test for 0 resistance at regulator points connections.
I.    While the points contact is in the upper position test between I and F.
J.   While in the lower position test between F and E.
K.   Note.  Do not file the points or they will quickly pit when used again.
IX.   Perform RPM test again.  Be sure all components meet specks before going forward from here.
A.   Reconnect all components but leave the regulator cover off.
B.   Start the bike and lock the throttle at 4000 RPM.
C.   The voltage should read between 14V and 15V.
D.   If voltage is low unlock the adjuster screw nut and turn the IN. NOTE do not run the screw into the coil winding or short the screw to something else with the screwdriver.
E.   If voltage is high adjust the screw OUT.
F.   For the 350F bend the arm up for and increase in voltage or down to decrease.
G.   Replace the cover and test the voltage again as the cover can have an affect on the field of the coil.
