Author Topic: 350F engine rebuild  (Read 473 times)
Offline chrisbc55
350F engine rebuild
« on: May 27, 2014, 06:01:36 PM »
I have a aquired a crank from a very low mileage  350F engine(I have just the crank and conrods) is it ok to use this crank and conrods in an engine rebuild using the good painted cases I have? I can read all the bearing markers on the crank and case and have worked out using plastigauge to replace the bearings
Cheers
