Author Topic: First oil change aftef hone/re-ring - magnetic oil filter?  (Read 2067 times)
« on: June 08, 2014, 12:29:19 PM »
...is a good thing.
Offline Deltarider
  • I'm back
Re: First oil change aftef hone/re-ring - magnetic oil filter?
« Reply #1 on: June 08, 2014, 12:38:37 PM »
Why?
CB500K2-ED Excel black
fendersrule
« Reply #2 on: June 08, 2014, 02:14:11 PM »
Should be obvious as to why, LOL.
Did this to my CB750 not too long ago. HDD magnets look a little better, but do the same job:
Good to see that this simple "mod" works!
Offline 750K
« Reply #3 on: June 08, 2014, 02:17:40 PM »
Hahaha, skeptics will always be just that. Even when looking at evidence of why something works or is a good idea.
77 Cb750, 78 Kz1000
« Reply #4 on: June 08, 2014, 02:21:32 PM »
The deposits wiped off like an oily powder.  It'd pass right thru the filter element.
AJK
« Reply #5 on: June 08, 2014, 04:30:16 PM »
I posted a little about what i found in my first oil change
http://forums.sohc4.net/index.php?topic=137902.msg1557668#msg1557668
I didn't run the magnets on the first pass (didn't think about it at the time), but i have them in now. The first pass will catch the most.
« Reply #6 on: June 08, 2014, 04:40:35 PM »
Why?
How can anyone with a modicum of intelligence even ask that..!!  Just wow.... ::)
« Reply #7 on: June 08, 2014, 04:45:53 PM »
Most skeptics I have known are complete fcuking retarded fools that have heads like a brick, nothing goes in and for that reason alone, nothing worthwhile comes out.... ::)  If its a communication break down then i understand, if its not its one of the stupidest questions i have seen on this forum.
« Reply #8 on: June 08, 2014, 04:54:34 PM »
the magnets are a good way to guage the running in,the debris diminishes rapidly,change the oil very early twice during the first couple of runs.
Offline Airborne 82nd
« Reply #9 on: June 08, 2014, 08:02:38 PM »
dave500 was the first person I saw this idea from many moons ago. I repair computer and have a good collection of magnets for all my filters. Thanks Dave
Offline mrbreeze
  • Not your average
« Reply #10 on: June 08, 2014, 08:32:17 PM »
...is a good thing.
Looks like what you find in the pan of an auto transmission. Its good to get that crap out of your oil. Its slow death to the engine...like real fine valve lapping compound. As long as you aren't getting chunks its a good thing!
MEMBER # 257
« Reply #11 on: June 08, 2014, 08:54:21 PM »
im always finding old computers in my dumpster truck job,out come the magnets,i actually have a couple of good running computers ive put together from parts aswell,lcd screens etc.
« Reply #12 on: June 08, 2014, 10:10:56 PM »
Guess some people have more faith in filters
« Reply #13 on: June 08, 2014, 10:34:55 PM »
AJK,s stuff at bottom of filter housing, did not go thru the filter either ..
Offline Deltarider
  • I'm back
« Reply #14 on: June 08, 2014, 11:22:10 PM »
How do you know?
               Brickhead
Offline mrbreeze
  • Not your average
« Reply #15 on: June 08, 2014, 11:24:58 PM »
I hear ya Dave. It's cheap insurance. I put 350 heads on a 327 years ago. I was real anal about the whole job because it was mine...not a customer job so I was able to take my time and keep everything real clean. Got everything spic & span before pulling intake and heads. I wasn't doing the bottom end so I had to keep everything up top clean while preparing gasket surfaces. I used lots of rags,brake clean,vaccum with hose reduced down small. Before it went back together I poured around a gallon of diesel through the intake valley and each cylinder. I really took my time but it came out good. I drained out the diesel and whatever it picked up on the way down put on new primed oil filter dumped in 5 qts. and fired it. Let it fast idle for a bit.....coupla quick revs let it drop to idle and shut it down. Dropped the fresh oil which was awful looking and swapped out oil and filter again. After that I like to just keep an eye on it for for a few days/miles. Looking for leaks.....make sure the level is good and the oil is clean. I've worked at shops that had me give the car back to the customer and have them bring it back after so many miles to get it's first change. I used to just cringe!!!
MEMBER # 257
