Author Topic: CB550 harness cb500 elec. Starter motor safety  (Read 1323 times)
Offline DavePhipps
    • Hillside Technology
« on: June 14, 2014, 04:06:46 AM »
Through an act of gross stupidity I literally burned up the wiring harness on the 500. I have a 550 harness laying around so I switch that over. Everything was good until I get to the starter motor safety unit. I get some advice on how to bypass it by . I can make a jumper from Green-Red to Green at the red block before the starter safety unit.
The problem is there is no Green-Red coming from the starter button. On the 550 you have a Red-Yellow and a Green-Red connecting to the starter motor safety unit from the starter button. On the 500 controls there is just a Red-Yellow.
Help an electrical idjit, please
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
Re: CB550 harness cb500 elec. Starter motor safety
« Reply #1 on: June 14, 2014, 05:45:01 AM »
Yes that's the one. There is also no clutch operated switch on the 500. At least from I can see when comparing 500 and 500 diagrams
« Last Edit: June 14, 2014, 05:48:19 AM by DavePhipps »
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
« Reply #2 on: June 14, 2014, 06:01:30 AM »
If I take the red/yellow and bypass the safety unit and go straight to the starter relay would that resolve the issue?
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
« Reply #3 on: June 14, 2014, 06:26:01 AM »
Alright time to go find my spade connectors then. I'll update later today.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
« Reply #4 on: June 14, 2014, 07:41:46 AM »
I've got continuity in the circuit up to the start button, but I'm at a loss of how to check a single wire start button.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
« Reply #5 on: June 14, 2014, 08:58:45 AM »
Start button is farked. Time to take apart and rebuild.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
« Reply #6 on: June 14, 2014, 09:47:37 AM »
Having my celebratory cigar. The starter button works!!!! The corrosion in there was frightening. Of course I lost and found the spring at least 3 times while doing this. I really need to remember to get my part holder out sometime. Yes, I'm a bozo. but a boze with a working start button!!
HOORAH!
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
« Reply #7 on: June 14, 2014, 12:28:25 PM »
Ohhhh.. very nice, the floor looks good too.
Just for a hoot I tried to start it. New plugs topped off the oil and it was go first time. I'm amazed  :o
It idled well too LOL.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
« Reply #8 on: June 14, 2014, 12:59:42 PM »
Nah, there are more problems. It's leaking massively from the oil pump, I need to go through the top end and find the oil seepage, then rebuild the most simple front brake in the world. Parts will be here Friday. In a few weeks my son should take his maiden ride/fall on the bike.
I can't wait, it's gonna be a blast.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
