Author Topic: front forks  (Read 664 times)
Offline Frenchmike
front forks
« on: June 15, 2014, 07:28:53 AM »
Just  drain 50ml out of my front forks from the 160 ml it put in , to see what difference it would make, to my what I call gudder , only it find it has made it worse , so may be using 10w fork oil or the atf that I have in it at the moment is just not thick enough.
May be I'm not getting damping at all.
I'm starting to clutch at straws now, as i have done everything you have all kindly suggested
Re: front forks
« Reply #1 on: June 15, 2014, 09:27:04 AM »
What bike are we talking about? I use 15W in my race bike otherwise ATF in the rest. Removing 50ml is a lot at once. Having only 110ml is far too little and will give too much travel as well.
Offline Frenchmike
Re: front forks
« Reply #2 on: June 15, 2014, 10:39:47 AM »
It's a 1977 400f and the book said from empty 160 ml
Re: front forks
« Reply #3 on: June 15, 2014, 01:57:52 PM »
Try a slightly heavier viscosity but do begin with 160ml again.
