Author Topic: 550K Speedometer Error Measured  (Read 706 times)
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« on: June 15, 2014, 06:37:42 PM »
For no particular reason I decided to measure the accuracy of the stock speedo on my stock '74 550. It was always clear to me that the MPH readings were optimistic! but how much so? I velcroed my Garmin to the tank and off I went. I found a consistent error of 4 mph, from 20 to 90 indicated, and as I suspected the speedo consistently overstated the mpg. My front wheel is stock, and I'm running the stock front tire 3.25x19 with very little wear.  I think the same was true for most cycle as well as automotive speedos of that era. My newer bikes are usually right on the money.
Re: 550K Speedometer Error Measured
« Reply #1 on: June 15, 2014, 07:05:02 PM »
hmmm, very interesting, thanks for posting.  This may explain why MJStone always rides so slow ;D on the relay rally, but swears his 500's speedo is nearly perfectly accurate according to his gps.  I don't know what kind of gps he has.  Maybe he will be along at some point to comment.
Offline Airborne 82nd
« Reply #2 on: June 15, 2014, 07:31:02 PM »
Well I don't have a gps or Garmin Hell I don't have a cell phone. But I do live in a small town and know the local leos and they have all that stuff and it is calibrated every year along with the speedometers in the cars. So I get him to go down the nearest four lane and light me up at 45 55 60 70 and I am off 10mph above what he is reading. This is on a 78 750K stock wheel & tire. That is why every one is flying by me all the time.  I can do the ton in a heart beat and don't worry so much about speeding tickets when out of town ;D
Offline Jayelwin
« Reply #3 on: June 15, 2014, 08:22:21 PM »
I've never seen an accurate speedo. My vstar has more of a sliding scale. Instead of a fixed amount of mph under its more like consistently 10%. Never tested my 750.
Sent from my iPad using Tapatalk HD
Offline flatlander
« Reply #4 on: June 16, 2014, 05:09:04 AM »
yes 10% under seems about right for my stock 550, also. i often ride with a gps and usually when it shows about 120kph the speedo is around 130. with the gps at 155kph the speedo shows an optimistic 170.
Offline Kenzo1979
« Reply #5 on: June 22, 2014, 05:28:17 PM »
Passed one of those "your speed" signals on the highway.  My stock '74 550 read 65mph, signal read 60mph.  Seems to have the same percentage of error.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
