Author Topic: 550 Brakes - Are They Very Good?  (Read 2925 times)
Offline tomk1960
  • "We are the people are parents warned us about."
    • Tom's Cycle Recycling
« on: June 22, 2014, 07:48:16 PM »
My son and I finished putting the front end of his '77 550 back together today.  That included new fork seals, rebuilt caliper, new piston and pads, and rebuilt master cylinder.  Bleeding went without a hitch and the brakes work, but they aren't very firm.  Is this typical of these single piston, single caliper brake systems?  I'm used to having a pair of dual piston calipers up front, so maybe I'm spoiled.  And the lever isn't super firm either.  I taped the brake lever on a hard squeeze when we were finishing up, so hopefully that will push any air left in the lines up to the master cylinder.
Coments?  Should I expect better than so-so brakes on this bike?  Thanks!
2001 Kawasaki Vulcan 1500 Classic
1984 VF1000F Interceptor
1983 CB1100F Super Sport
1983 VF750F Interceptor
1982 CB900F Super Sport
1978 GL1000
1977 GL1000
1974 CB750 Four
www.tomscyclerecycling.com
Offline Farley121
  • 78 CB550K
Re: 550 Brakes - Are They Very Good?
« Reply #1 on: June 22, 2014, 08:06:33 PM »
They are notorious for mushy brake feel.  Braided lines make a huge difference.  I ended up replacing only the top line from the master cylinder to the brake light switch with braided, and it made a big difference.
Offline Thamuz
« Reply #2 on: June 22, 2014, 08:17:17 PM »
I had to go all stainless.  It was spongy even with one.  It is a lot better now.  There is a bit of sponge from old rubber hoaes expanding a bit under pressure. Not a lot, but just a tiny bit.
Go stainless.  I got mine from Slingshot cycles, right size n all.
1979 Yami Chopper XS1100s
1978 CB750k
1977 CB550F
1974 CB550k
Parts bike for the 550's
Offline billingstitan
« Reply #3 on: June 22, 2014, 08:27:16 PM »
After a spell away from my 550, I'm always caught a little off-guard w the soft front brake.
Rarely touch the back brake on my sport bike, but definitely use both on my CB550. Thinking about adding a parachute on the rear fender for good measure.
That said, it should definitely pull to firm - if it's getting all the way back to the grip then you need to bleed it again, or something else is off.
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
« Reply #4 on: June 23, 2014, 12:11:03 AM »
if the hoses are the 40 year old ones replace them,the standard hoses work fine,grab an old hose as you pump the lever,does it swell or pulse much?
Offline flatlander
« Reply #5 on: June 23, 2014, 12:54:49 AM »
like dave said, new hoses should firm things up. even then, if you're used to modern brakes it won't be the same. welcome to the 70s  ;)
you could install a second disc and caliper. it won't exactly double the braking power but gives you some more.
« Reply #6 on: June 23, 2014, 12:58:54 AM »
any late model bikes ive ridden have too good brakes!
Offline flatlander
« Reply #7 on: June 23, 2014, 01:10:47 AM »
yeah it can really take some getting used to being that gentle - i remember that  :o
Offline tomk1960
« Reply #8 on: June 23, 2014, 06:01:33 AM »
I have dual discs on my '74 750, so I know how good the brakes can be on these old bikes.  Based on what I'm hearing here, the brakes on the 550 aren't too far off from normal.  I'll switch to braided lines as soon as Shawn (Slingshot) is back from vacation.  In the meantime, I'll bleed them again to see if it improves them at all.
Thanks for all the inputs.
1978 GL1000
1977 GL1000
1974 CB750 Four
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
« Reply #9 on: June 23, 2014, 06:21:53 AM »
Braided lines and a modern master cylinder will make all the difference. You can get a Nissin with a 14mm bore for a single disc system for a reasonable price. I run one with a 16mm bore for a dual disc on my CBX. Made a huge difference.
Offline wardenerd
  • '77 550F '81 650C
« Reply #10 on: June 23, 2014, 06:37:56 AM »
I got the stainless brake lines one of the guys on here sells and that firmed up the feel even with just a rebuilt master cylinder.  My problem was the lack of brakes when the disc got wet.  I had my disc cross drilled and it made all the difference.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #11 on: June 23, 2014, 07:00:45 AM »
What fluid did you use
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Online Stev-o
« Reply #12 on: June 23, 2014, 07:08:21 AM »
My 550 has very good stock brakes.
Offline Mo
« Reply #13 on: June 23, 2014, 10:37:36 AM »
My 500 is pretty good too! I'm a moderate rider, and find I rarely need the front brake.
Offline tomk1960
« Reply #14 on: June 23, 2014, 11:53:12 AM »
DOT3 as specified.
The lines will definitely be upgraded soon and hopefully that will firm up the lever.  (along with a re-bleed)  The brakes will be fine for non-aggressive riding, but I would never want brakes like these on my Interceptor or 1100F.
1978 GL1000
1977 GL1000
1974 CB750 Four
« Reply #15 on: June 23, 2014, 11:55:31 AM »
I can second that. As an experienced motorpolice instructor once said to me: with these old Honda brakes you can brake like a moron but you will not be in danger. He learned me the right brake method and how to control my bike under any circumstance.
What do you use if not the front brake, your feet? It's more than 60% of stopping power! Using your rear brake as a primary is not only stupid, it's dangerous.
I agree, the rear brake is a secundary brake: 70% front 30% rear, unless you go down a steep little mountain path with rubble. Then you won't touch the front brake lever.
These old Honda brakes are still (even today) well within what the legislator demands. It's up to your style of riding. But a warning: in rain they're hopeless the first revolutions.
« Last Edit: June 23, 2014, 12:04:56 PM by Deltarider »
« Reply #16 on: June 23, 2014, 12:34:25 PM »
learn to use the front brake moderate rider or not!your not riding properly otherwise.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #17 on: June 23, 2014, 01:47:09 PM »
+1 for the Slingshot SS braided hoses. They will eliminate SOME of the mush. You mentioned above rebuild of the master cylinder. Did you bleed it separately? If not give that a try before you do your final caliper bleed. My experience is that a bit a of air can hide in the master and not be bled from the caliper.
« Last Edit: June 23, 2014, 06:02:04 PM by CoachDoc »
« Reply #18 on: June 23, 2014, 02:00:25 PM »
My CB550 brakes are good.
I do have to use my whole hand to screech the front tire, though.  I like it that way.  Very little risk of slide out in the corners.
I did replace my old lines with SS, and have bled the system for a rock hard lever.
I was taught and have always used both front and rear brakes simultaneously.  Why ignore 10 to 30 percent of your stopping power?  I've found it a valuable technique to employ.
Offline Bailgang
  • Scott
  • Indiana
« Reply #19 on: June 23, 2014, 02:48:32 PM »
New brake lines would help, SS lines even better. My guess is that as long as your son rides that 550 and ONLY the 550 he will learn what to expect in regards to braking and all should be fine, it's when you ride one bike then hop on another say a more modern bike and that's when problems may arise. One time my youngest son and I swapped bikes for a ride, I had to completely re-accustom myself to the brakes on his cbr600 otherwise I would've went over the bars if I grabbed the brakes on it the same as I did on my 550. On the other hand my kid almost blew right through an intersection while on the 550 because the brakes he had gotten used to on his cbr just weren't there on the 550.
« Last Edit: June 23, 2014, 04:04:18 PM by Bailgang »
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline tomk1960
« Reply #20 on: June 23, 2014, 05:44:08 PM »
Before I connected the brake line to the master cylinder, I primed the master.  I do it by pumping the lever with a finger over the banjo hole, release, pump some more, release, and eventually a healthy gush of fluid comes out and then I connect the line.  Is there more to it than that?  I know if the MC is airbound, bleeding is next to impossible.
1978 GL1000
1977 GL1000
1974 CB750 Four
Offline CoachDoc
« Reply #21 on: June 23, 2014, 06:06:54 PM »
Sounds like you got it right for bleeding the MC. I also like the tying of the lever to the handle bar overnight, which got rid of the last bit of softness after my rebuild of the MC, caliper, etc. MY lever if very firm now, and the only thing I did that you haven't done yet is new SS braided hoses. That may get you where you want to go. Good luck.
Offline tomk1960
« Reply #22 on: June 23, 2014, 06:57:15 PM »
Shawn at Slingshot sells his braided lines for a very good price, so I'll order some when he gets back from vacation. Tying the lever overnight might have helped a little, but I wouldn't call the lever "hard" by any stretch.
For anyone interested in how I prime master cylinders, here's my YouTube how-to video:
https://www.youtube.com/watch?v=m4wlSQDsEHw
1978 GL1000
1977 GL1000
1974 CB750 Four
Offline CoachDoc
« Reply #23 on: June 23, 2014, 08:42:10 PM »
Nice video, Tom. You should shortly join the ranks of the experts and gurus on this site as you get more into these older SOHC's.
