Where to begin? Can't tell you where really, you need to provide information for us to help you with.
If your information for specs is just "correct" well, then I guess that's that. Instead, things like "floats set to 26mm" helps, that is real data.
So you rebuilt your carbs and everything is set correctly, "the whole 9 yards." What else changed, pod filters? Exhaust? If nothing else changed, then you didn't do everything correctly.
From what little info available, it sounds like you're lean, and that rev up before dying sounds like what happens when you run out of gas. I'm not saying you're out of gas, I'm saying that what you describe is a symptom of running lean. You might want to double check your slow jets.
