Author Topic: CB550 Front Disc Bolt Pattern? Interchangable Modern Discs?  (Read 2560 times)
Offline AMD500
« on: August 16, 2014, 05:48:43 PM »
I know this topic has been covered, but I can find the info im looking for through the search option...so here it goes.
Tired of dealing with sh*tty braking. On my xs650 I was very easily able to upgrade the performance by using a more modern rotor and and Brembo Caliper from a Ducati monster. Great braking. easy to do. people sell kits for this. all together awesome.
Before you tell me to swap the front end...let me say I have the suspension set up to my liking. not looking for a modern fork. just modern brakes.
1. Is anyone making similar kits for cb550's/cb750's? adaptor plates and such?
2. does anyone know what modern bikes have discs that use the same bolt pattern at the cb550 (or what the bolt pattern is)?
Thanks for the help!
More info: I have already replaced the lines with stainless, and upgraded master cylinder. still think the stock brakes suck.
« Last Edit: August 17, 2014, 12:53:08 PM by AMD500 »
Re: Another CB550 Brake Quesiton
« Reply #1 on: August 16, 2014, 08:41:07 PM »
Have you considered duel discs on the front?  Scott is selling rotors and has them listed in the for sale section.
« Reply #2 on: August 16, 2014, 09:00:53 PM »
turboguzzi made brackets for CB500 forklegs to use small Brembo F05's. The discs are Suzuki I suggested he use because they're much lighter but otherwise the same offset & diameter as the 500/550's
http://forums.sohc4.net/index.php?action=dlattach;topic=44616.0;attach=64809
I use the same calipers on mine but since I use 750F2 forks the caliper brackets are simpler. These calipers are twin pistons and a good choice for a middleweight offering vastly improved braking. Mine are modified Honda rotors.
Just a couple ideas for you. I have thought of using a larger 750 rotor with the larger Brembo F08 caliper, but this setup works so well I hate to change!
« Last Edit: August 16, 2014, 09:04:21 PM by bwaller »
Offline AMD500
« Reply #3 on: August 17, 2014, 08:05:25 AM »
thanks for the responces guys! I dont post a lot on the forum, because I usually can find what I am looking for in the search, and I dont really have much Knowladge to add to most discusions. When ever I do post, everyone is always very helpful. cheers to that.
calj737, didn't mean to offend. I know these breaks were the tits at the time these bikes came out. Just been spoiled by modern brake tech...You are correct about people making adapters etc, what I am interested in is finding what specific rotors will work with our hubs bolt pattern (understanding a spacer will be needed to get the offset correct). Making a spacer and caliper  bracket is all doable. I know on the xs650 forums there are lists/spreadsheets/diagrams etc. that outline parts the bolt right onto the bike. Figure someone might have made the same sort of thing for our Honda CBs. maybe not. Those XS guys have too much time on their hands.
bwaller, turbo guzzi always has the coolest tech...still trying to fab up a hydraulic clutch actuator like he has on his CB500f. your brakes look great too. my thought is that there are so many of those Brembo Gold calipers out there for so cheap (ducati has made a lot of monsters), that i would like to go that route with the caliper. they might not look period correct, but they stop on a dime, and it's easy to get parts a rebuild kits for them. Seems like some enterprising young machinist could get quite a bit of interest if they make a nice bolt on spacer kit for the Brembo Golds (pandemonium cycles did this for xs650s, and now you hardly see on without the brake upgrade).
Ill keep updating this page to show what i come up with. might just buy Scott's twin disc setup for the short term, and then try to sort an upgrade during the chilly shed months.
« Reply #4 on: August 17, 2014, 10:20:40 AM »
You're right about using something more modern, I should have mentioned TG & I both needed to use the older style Brembo calipers to be "period correct" for our vintage race classes.
Good luck.
Offline AMD500
« Reply #5 on: August 17, 2014, 12:51:39 PM »
So do you guy's or anyone else know the bolt pattern for the the stock disc? figure someone must know.
Offline Garage_guy_chris
Re: CB550 Front Disc Bolt Pattern? Interchangable Modern Discs?
« Reply #6 on: August 17, 2014, 04:14:52 PM »
I was fooling around at a motorcycle wrecker tyring to match the bore and the hole pattern to the 6 hole honda pattern. 1 managed to match up a set of mid 80's yamaha ??F??400 it was definately a 400cc but i cant remember the prefix or letters?  maybe someone knows the yammy's enough to add to this.
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #7 on: August 17, 2014, 11:20:46 PM »
An FZR 600 disk has the same bolt pattern but different offset. You would have to have a spacer made and get longer bolts to make it work.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline AMD500
« Reply #8 on: August 18, 2014, 06:08:17 AM »
Dave, Thanks! great info. did some digging, if this is the case then this info below applies...so with a crafty spacer should be able to fit the Brembo Golds. Will keep everyone posted:
theres plenty of discs about that will fit the FZR - Range
Yamaha shares this rotors: 320mm
· FZR 250 87-
· TDR 250 88-92
· TZR 250 87-92
· SRX 400 (3VN1/3VN2/3VN5) 90-96
· SRX 600 (3SX) 90-91
· SZR 660 96-97
· FZR 750 Genesis 87
· YZF 750 R/SP 93-97
· FZR 1000 Genesis 87-88
· FZR 1000 EX-UP 89-95
· XJR 1200 95-98
· XJR 1300 (5EA1) 98
To make the list complete:
000 Specs:
- outer diameter: 320 mm
- inner diameter: 64 mm
- thickness: 5 mm
- setback: 10,5 mm
APRILIA:
- CAPONORD RAID from 2003
- ETV MANA from 2002
- RSV MILLE from 1998 till 2000
- RSV MILLE R 2000
- RSV MILLE SP 2000
- SL 1000 FALCO 2000
DUCATI:
- 620ie MONSTER from 2001
- 620 SS from 2003
- 748 DESMOQUATTRO from 1994 till 1997
- 748 E/S & R from 1998 till 2002
- 749 also S from 2003
- 750 SS from 1991 till 1998
- 800 SS from 2003
- 800 SPORT from 2003
- 851 from 1988 till 1991
- MH 900 E 2000
- 900 M MOSTRO from 1993 till 2000
- 900 SS from 1991 till 1998
- MOSTRO S4 from 2001 till 2002
- 916 all models from 1994 till 1998
- 996 from 1999 till 2001
- 1000 MOSTRO from 2003
YAMAHA:
- YZF 750 R from 1993 till 1995
- FZ 1000 R from 1987 till 1989
- FZR 1000 EXUP from 1989 till 1995
- XJR 1200 from 1994 till 1998
Hope it helps someone struggling to find replacements!!!!!!!
BOLT PATTERNS ARE THE SAME
LIST IS FOR FRONT ROTORS ON THE FZR RANGE OF 1000'S AND 750'S WITH 320MM FRONTS, NOT REARS.
Offline DavePhipps
« Reply #9 on: August 18, 2014, 11:34:48 AM »
I forgot to mention that you will have to make a carrier like bwaller and turboguzzi did. The disk is a bit wider in diameter so the stock brake position will need to be modified.
I'll also mention that I checked clearance using my FZR caliper and it interferes with the spokes. FunJimmy took some CBR calipers and trimmed the caliper to fit on his brake setup.
BTW is your name the K6-2 500 or an APU?
« Last Edit: August 18, 2014, 03:14:26 PM by DavePhipps »
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
