Author Topic: CB750 K4 Turn Signals  (Read 976 times)
Offline jprochnow
« on: December 15, 2014, 07:06:49 AM »
Did the k4 have daytime running lights? My front turn signals have 2 wires coming out of each but from the online catalogs it only shows 1. This is a project bike that is currently taken apart and I was curious.
DH
Re: CB750 K4 Turn Signals
« Reply #1 on: December 15, 2014, 07:28:03 AM »
....Edited my post..Not daytime running lites, just front running lites/when headlite is on. IIRC, wiring is correct, as the front signal sockets ground via the signal housings and ultimately the h/l housing mounting bolts, inside the h/l housing itself,  so no third wire coming from socket.
« Last Edit: December 15, 2014, 07:49:03 AM by DH »
Offline jprochnow
« Reply #2 on: December 15, 2014, 07:31:02 AM »
Ok so should it have a single wire coming out of the turn signal or two?
DH
« Reply #3 on: December 15, 2014, 07:42:30 AM »
Two. one for turn, one for running lite. (Sorry, edited my previous post, as I left something out.)
« Last Edit: December 15, 2014, 07:52:56 AM by DH »
Offline jprochnow
« Reply #4 on: December 15, 2014, 08:34:41 AM »
Ok just to reverify I will have 2 wires coming out of each signal that plugs into the harness? The signal stem is technically the third connection for ground?
« Reply #5 on: December 15, 2014, 09:36:16 AM »
10-4, correctomundo, yavol, yep, affirmative.  Some guys put these sockets in the back and added red lenses for some extra rear lights.
