Author Topic: 1972 CB500 1st build but not last for sure  (Read 1093 times)
Offline Jeremy28c
« on: December 27, 2014, 07:31:01 AM »
Well a guy at work gave me three motorcycles and this 72 cb500 is going to be my first build. I bought a 78 cb750f that was already tore apart and started but since I wasn't the one that tore it down I was thinking I would get the 500 going first. The reason it has sat for the last 15 years was the previous owner said the oil light started coming on so he changed the oil. It would stay on at idle but if you hit the throttle it would go off. I bought a used oil pump, sender, o-rings to pull the oil pump out and check it then put that all back together. I pulled the carbs off and they were as suspected all gummed up, so I'll be sending those of the get cleaned and rebuilt. My question is about the lower end. I am going to pull the head and cylinder and at least put new pistons and rings in. With this motor having 43k miles and only knowing what the last owner said what are your guys opinion about pulling the bottom end apart. To be honest the bearing sizes do confuse me alittle. I also would have to get all new rod bolts and nuts. I can find the bolts ($15ea) but haven't found the nuts yet. I think I know what I should do but would love to hear some other opinions on what you guys would do. Thanks  More Pictures to Come
Re: 1972 CB500 1st build but not last for sure
« Reply #1 on: December 27, 2014, 08:38:15 AM »
Welcome Jer.  CB500 are good bikes, I had one.
If not too late, I would suggest getting the bike running then determine the need of a top end and tranny work. These bikes, if properly maintained [tune ups and oil changes] are known to go 50K miles or more with out a rebuild.
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #2 on: December 27, 2014, 08:49:45 AM »
Welcome!! I second the hone and re-ring route, unless your're having trans issues, I'd avoid splitting the cases. Good luck!
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline Jeremy28c
« Reply #3 on: December 27, 2014, 09:14:05 AM »
I checked the compression and number 3 was only about 40lbs. The rest were all 100-125 thats why Im thinking just top end if I can get by with it. The carbs are so bad I dought it would even start.
« Reply #4 on: December 27, 2014, 12:15:24 PM »
A good cleaning/rebuild of the carbs is a must.
Offline rb550four
« Reply #5 on: December 27, 2014, 12:50:57 PM »
You may just have a sticky valve on #3 not seatingproperly or the gauge wasn't seated properly.
I'd do the compression check again to be sure.
 Of course there is always a chance of blow by with broken rings too. If the test came out the same next time I think it would be time to take the top end down and find out why.
