Author Topic: Gouge on the head surface  (Read 792 times)
Offline bambuhiphop
« on: January 22, 2015, 10:52:59 AM »
So, I feel like this gouge should greatly concern me. I had to go back through pictures to see when this happened. I don't remember it but it seems to have occurred when a stud snapped. Head still needs to be decked and cleaned.
Am I right to be concerned? If so, is there anything I can do or have done to fix???
Offline lrutt
Re: Gouge on the head surface
« Reply #1 on: January 22, 2015, 10:54:37 AM »
trying to picture where on the head this is. If that leads to the combustion chamber, that might be a problem.
« Reply #2 on: January 22, 2015, 11:25:03 AM »
head surface or top case surface?
need wider angle picture...
« Reply #3 on: January 22, 2015, 11:42:32 AM »
just dress the burr and use a little hard setting gasket compound on that area.
Offline bambuhiphop
« Reply #4 on: January 22, 2015, 11:44:11 AM »
Between 1 and 2 on top of the case.
« Reply #5 on: January 22, 2015, 11:57:53 AM »
+1
Its where your sleeve, and its large o-ring sit.
Id also copper spray the base gasket.
Offline bambuhiphop
« Reply #6 on: January 22, 2015, 12:00:44 PM »
+1
Thanks Guys, was starting to freak a little. Getting into to areas where my knowledge is not as robust.
Offline eigenvector
« Reply #7 on: January 22, 2015, 07:16:04 PM »
I think you'll be okay.  I did the same thing to mine trying to scrape off the head gasket - didn't affect the engine at all.
Like the other's say - fill it with a decent compound and dress it flat.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
