Alright I think the carbs are ready then. I just tried doing my timing for my ignition (with the Daiichi plate and points) in order to rule out (or verify) that the Daiichi products are the problem. When I use my 12v lamp, it glows very dimly when the points just begin to separate. I have it grounded to the engine case and have the probe touching the metal arm of the point. It glows brightly when I use it to test continuity everywhere else, so I don't know why it is only glowing very dimly at the points. Voltage at the points is about 10.8v or so. I don't think this is the cause though, because other wires that register a similar amount cause the lamp to glow brightly.
Because of the above issue, I used the spark plug grounded to the cooling fin of the engine to time my points. I use the spark from the plug to indicate when the points are beginning to open. However, when I use this method and turn the crank slowly, I get multiple sparks. For instance, when I'm testing the 1-4 point, I am approaching the F mark on the advance plate. About 1mm away from reaching the mark, I get a spark. When I continue to slowly turn the crank, it sparks again, but stronger, when the F mark is aligned. Is this supposed to happen? I replicated the results multiple times to make sure that it was a recurring event.
