After rebuilding the CB500 forks for my Cb550K build with new Forking by Frank tubes and new seals and crush washers, I was still getting a little seep of fork oil around and below my front hub axle on the brake rotor side.
Anyway, I took it all apart today thinking I'd put a new crush washer on with a bit of copper sealant, torque it up nice and call it a day. Well, not so simple. I took a good look at the surface that the crush washer is sealing against and it's gouged to #$%*. It was leaking from tho area since day one with this bike and now I can see why. Your guess is as good as mine as to why this happened.
I think I am going to take it to a machinist to knock down the material up to the bottom of the gouge. It should only be 5mm or so at the most. That should leave a flush surface for the copper crush washer to seal against. Does anyone see any reason not to do this?
I'd be open to hear suggestions on alternative ways to fix this, or is anyone else has had anything similar happen.
