I'm currently giving the entire front end the what-for (progressive springs, roller bearings in the neck, and lots of polishing), and one of my fork legs has a stuck piston. The bike's a K2, but I'm pretty sure it's running an earlier model fork (I'm the third owner). Mine looks nothing like the one in the parts manual. Anyhow, for purposes of identification, from the bottom of the fork tube up, there is 1) a circlip, 2) the piston, 3) a skinny little ring, 4) another circlip. You following me? Hope so. So I removed the circlip on one tube& the piston slid right off, but on the other tube the piston wouldn't budge. I hit it with WD-40, then with liquid wrench, but nothing. Is this going to affect fork performance at all? I assume that it really only needs to be removed if it needs to be replaced due to a shrinking outer diameter.
