Author Topic: I want to lower my 1977 CB750A safely  (Read 1634 times)
Offline dave77tac@gmail.com
« on: April 02, 2015, 12:04:33 AM »
Hello I'm sure this topic has been discussed before, but I can't seem to find it. I would like to lower a inch or two. What would I need to do, and what parts would I need to lower the front and rear the same amount. Thanks for help.
Offline dave the welder
  • dave the welder
Re: I want to lower my 1977 CB750A safely
« Reply #1 on: April 02, 2015, 12:44:15 PM »
on the back use shorter shocks(people usually adapt from a harley)or use lowering blocks.you can sometimes find them on EBAY.if you use blocks you might have to remove or modify chain guard.to lower front you loosen the clamps on the trees,slide forks up however much you want and tighten WARNING if you go more than an inch or so you might crunch the fender into the frame if you bottem out the forks on a big pothole
don't buy it build it
« Reply #2 on: April 02, 2015, 01:38:22 PM »
Thanks I think a inch will do it. I'm also wondering 1975 CB750f 2 into 1 exhaustsand headers will work on my 1977 CB750A
