Author Topic: '73 CB500 right crankcase cover gasket replacement  (Read 1286 times)
rudimentaryjr
« on: May 19, 2015, 12:42:57 PM »
Replacing the crankcase gasket, didn't see that gasket sealant is needed for assembly. Is this true? If not, what gasket sealant should I use? Thanks in advanced!
« Last Edit: May 19, 2015, 01:30:30 PM by rudimentaryjr »
rudimentaryjr
Re: '73 CB500 right crankcase gasket replacement
« Reply #1 on: May 19, 2015, 01:28:30 PM »
It's the crankcase cover on the kickstarter side. It's the paper gasket, picture attached from manual. I was researching and using a non-hardening sealant like the Permatex Form-A-Gasket was being used on oil pan gaskets or valve cover gaskets.
rudimentaryjr
Re: '73 CB500 right crankcase cover gasket replacement
« Reply #2 on: May 19, 2015, 02:45:32 PM »
Thanks calj737! I appreciate the response and correction on the proper name for the Clutch basket!
