Author Topic: Rickman Honda front wheel bearings  (Read 1218 times)
Offline captaink
« on: June 03, 2015, 08:01:11 AM »
Hi, Im currently stripping the wheels down on my Rickman Honda project.
The wheels are Kawasaki 7 spoke, 650cc or similar.
Rear wheel is done but  its the front wheel. Has anyone taken these front bearings out as there could be a shoulder on the inside that stops you pushing the bearings out.
I know there probably Kawasaki but there on the Rickman Honda and Im sure someone has come across this.
Ill get there in the end but Any views welcome
Regards Keith
CR750 Replica Honda colours
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
Rickman 750 project
CR 750 dick Mann project
1964 series 1 E type jaguar
Gt40
" Greedy I Know "
Re: Rickman Honda front wheel bearings
« Reply #1 on: June 03, 2015, 10:31:17 AM »
Keith, sounds like you are not sure if the wheels are Kawasaki? The 7 spoke Kawi wheels were patterned after Morris wheels. In the attached pic, the Morris is on the left, and a 550 Kawi wheel is on the right. The spokes have a "+" shaped cross-section, while Lester (and Yamaha clones) have a "H" shaped cross-section.
« Reply #2 on: June 03, 2015, 10:43:23 AM »
 Some guys have used a 1/2" concrete anchor that expands to grip the inside of the bearing to pull it out. I haven't done this particular wheel but a drift pin with the end ground to catch an edge might work.
Offline captaink
« Reply #3 on: June 03, 2015, 12:17:13 PM »
Your right I'm not sure what they are , when I can post a picture I will.
Removal of the bearing with an internal puller seems the only option really but the lip its got to attach to is so small, I cant see a manufacturer making it that difficult to get the bearing out.
It will come out one way or another, just wondered if there was a special tool or something
Cheers guys
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #4 on: June 04, 2015, 11:37:05 PM »
Bearing now removed. Had to use a small screwdriver then a punch just catching the spacer edge.
The spacer and bearing pushed out then the other bearing was easy.
There's no play in the bearings but for the small cost of replacing them it's a no brainer.
The spacer just needs a little refacing.
Wheels now ready to go to the refurbishers.
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
« Reply #5 on: June 05, 2015, 12:00:09 AM »
If they are Kawasaki wheels they will have "made in Japan" and or  "Enkei" on one of the spokes, Morris were made in the USA... ;)
Pics please... ;)
Offline captaink
« Reply #6 on: June 17, 2015, 02:31:29 PM »
Made in Japan stamped on them...
Cheers
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
