Well, much to Redline's chagrin... I am going to try to resurrect this a bit because I don't want to stop tuning until there is zero hesitation across all throttle ranges. Noticed stumbing from 1/4 to nearly 1/2 (probably 3/8) throttle last night in 1st gear. But, man.... when it hits about 3/8 throttle the thing rips like hell! 1/4 to 3/8 in 1st gear is the only time I notice any stumbling, as I like to wind it up... so it isn't a HUGE deal, but I want as perfect performance as I can get. With this symptom, am I correct in saying that I have a rich condition in low RPM's? Here are my stats again:
MotoGP Werks 4-1
UNI replacement foam filter in stock airbox with all necessary hoses attached
087a carbs, clean as a whistle
Fuel levels verified to 4mm below bowl mating surface
105 mains
Needle clip in 3rd position (stock is 4th)
Air screw currently at 1.5
Last night, I played with the air screw going from 1.75 to 1.5 to 1.25 to see if there was any noticeable difference in the stumble.
1) It seems to me, there is less stumble at 1.75, but popping on decel is considerably more.
2) Starting at 1.5, the decal popping gets better, but seems like more stumble.
3) Decel popping is nearly gone at 1.25, but stumble is even more noticeable.
Side note: I need to re-check my timing. It was spot-on prior to the last carb removal, but I have neglected to check it since then, and I have definitely messed with my idle screw since, so I may be idling at a different RPM than where the last timing was set (bad tach). And yes... I have performed a vac sync since the carbs were reinstalled with the 105's and clip change.
My question is.... should I be moving the needle clip back down to 4th position? Then, play with the mixture screw? Or, is it just a matter of miniscule mixture adjustments.
Thanks in advance, ya'll!
Kyle
