Author Topic: PPG Epoxy Primer - Anyone with experience?  (Read 1007 times)
Offline jamesbekman
« on: June 19, 2015, 07:01:43 AM »
Hi,
I was wondering if anyone has an experience using PPG DPLF epoxy primer.  If so I have a question or two.  Im coming into a few problems with orange peel and am thinking of doing a high build primer over it, or trying to recoat with it thinned out to minimize the peel and the wet sanding for base coat.  Im ending up hitting metal on the frame and down to the gel coat on the fiberglass tank I have in a few spots.
James
Offline dusterdude
Re: PPG Epoxy Primer - Anyone with experience?
« Reply #1 on: June 19, 2015, 07:24:08 AM »
Pm me,i can help
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline nvr2old
« Reply #2 on: June 19, 2015, 09:57:49 AM »
Epoxy primer is just designed to go over bare metal, followed by the high-build.  Spray 3-4 coats of urethane high-build, then sand it smooth with 400 then lightly with 600 before applying your base coat color and then the clear.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline Vinhead1957
« Reply #3 on: June 19, 2015, 12:44:16 PM »
Love it when you guys talk dirty
Offline chewbacca5000
  • I polish covers!
« Reply #4 on: June 19, 2015, 12:46:40 PM »
I like urethane myself as it sprays better, but epoxy offers more protection.  You spraying metal or plastic?
Offline ofreen
« Reply #5 on: June 19, 2015, 01:53:19 PM »
I used to use it quite a bit. Tough stuff and easy to work with.  I was mixing some up one time when some spattered on my big toe nail.  (I was wearing sandals, spare the lecture.)  I didn't notice it until a little later by which time it had dried.  I decided to leave it to see how long it would stick.  It went a month through daily showers and abrasion inside shoes and socks before I noticed it was gone one day.  I thought that was impressive.  I used to use it on car and jeep frames after blasting.  I quit using it when the price got ridiculous and went to Zero Rust for the same work.  I heard they changed the formulation a while back, hopefully it is still as good.
Greg
'75 CB750F
Offline tlbranth
« Reply #6 on: June 19, 2015, 06:35:24 PM »
Greg - I'm definitely switching to urethane for my toenails. I hope it's available in my color.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline ofreen
« Reply #7 on: June 20, 2015, 07:09:32 AM »
 ;D
Greg
'75 CB750F
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #8 on: June 20, 2015, 11:10:35 AM »
Don't know if you're using an HVLP or siphon gun, but in general orange peel comes from spraying at too high a pressure if the paint viscosity is correct.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline turboed13b
« Reply #9 on: June 20, 2015, 11:16:10 AM »
I would recommend following the tds for the paint you are using. For some paints it is a big no no to sand the base coat as it will cause adhesion issues and if you are spraying mettalic it will ruin it.
