Got a Frankenbike cb750 with some electrical issues.
I know the engine is a 78. The frame is a 76 but not sure what year the harness is. Thought it was a 76 harness but there is no starter safety module I can find. Where would this be? So the bike starts and runs great that's the good news :-) . Probs are :
No power to headlight- No voltage on the fuse block on the headlight fuse either side or the tail light.
Brake light isn't working- running light works
Also e start isn't working . Continuity tests good to solenoid.Starter engages when bridging the posts. Not getting any voltage from starter switch when pressing the button. Not getting any going into it either.
Noticed a few things, clutch safety switch has one wire broken at the clutch switch. With this disconnect I am thinking it will not e start. Neutral light comes just fine .
My gut feels like the starter safety control module Or lack there of is causing some estart issues. Kicks just fine.
Should there be power to the headlight fuse when the
Ignition is on...?
There isnt.
This bike had no key so I am hot wiring it till the key comes in. Just twisting the red and black together..
Is there any need for the brown and brown/white wire . I was thinking that these are just for key switch positions that leave the tail light on and not essential.
really close . I have a wiring diagram but this bike isn't exactly virgin in the electrical department and I don't think the control pods match the harness year ( there is a headlight on off switch on the right pod)
I have no problems bypassing things on this harness if need be. Not trying to bring this thing back stock just need a brake light , a headlight ,and e-start would be nice too. Not to much to ask hUh?
