Author Topic: 750 motors and seal kits  (Read 1564 times)
rdub3017
« on: October 25, 2006, 11:00:00 AM »
I have recently picked up a few motors and a 72' 750. There was oil leaking out of the head over the exhaust and a lot of smoke coming out of the pipes. Does anyone have suggestions as to what the best engine seal kits are?? One of the other engines looks to be from a 75....were there any improvements in the 75 motor that would make me want to swap to the newer motor??
Thanks!!
Offline tsflstb
Re: 750 motors and seal kits
« Reply #1 on: October 25, 2006, 11:03:31 AM »
Buy OEM Honda kits.  There are some cheap sub-par knock-offs out there.  I learned the hard way.
« Reply #2 on: October 25, 2006, 11:48:12 AM »
As far as your 75 engine goes that depends on whether it is a F or K. The 75 F has a hotter cam and higher compression so it will perform better. Also the tranny has a better performance ratio.  It also depends on what year the other engines are. You need to look up the engine serial numbers to determine this.
rdub3017
« Reply #3 on: October 25, 2006, 12:55:46 PM »
Thanks! As far as I know the other motors are K models. I will have to reference the numbers when I get home. If I replace the seals in the top end should I machine the head for a good flat seat on the motor??
Offline angeldeville
  • You meet the nicest people on a Honda!
« Reply #4 on: October 25, 2006, 01:10:16 PM »
The current oem gaskets are made by Vesrah, and the Vesrah are cheaper than oem.
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
« Reply #5 on: October 25, 2006, 06:00:13 PM »
If I were going to machine the head surface to insure a good seal I'd also do the same with the top surface of the cylinders. An added benefit to this will be a slight compression/HP increase. Now, with head leaks in mind, you might want to consider a set of after market heavy duty cylinder studs such as APE (support our forum members). The OEM studs have a tendency to stretch ever so slightly allowing leaks. The other annoying area that leaks and which can be a greater leak, is the "biscuit" seals under the cam towers. Definitely replace these. Be forwarned, you can spend a bunch of $$$ if you start to get picky. Oh yeah, our member Mike Rieck does fantastic head work if you want some real HP. I'm sure that could be combined with milling the head/cylinder surfaces.
