Author Topic: 550 Cam Cover Removal steps  (Read 3148 times)
Offline redrider736
« on: August 04, 2015, 08:34:28 PM »
Planning to swap out my 78 550 Cam to a 79 650.. Have read everything I can about doing this swap, but can't seem to find the steps to remove my Cam Cover off of my 550.. (550 motor is in bike and 650 Cam is in hand)
Don't want to jump in before knowing the steps..
any links or help would make my summer holidays !
78' CB550k (Not Run'n / Basket Case Project)
77/78 cool 2 member #269
Offline flatlander
Re: 550 Cam Cover Removal steps
« Reply #1 on: August 05, 2015, 04:32:47 AM »
what cal says... and look here: http://manuals.sohc4.net/cb550/
part 2 for the process
part 1 for torque specs
Offline redrider736
« Reply #2 on: August 05, 2015, 09:08:00 AM »
Believe it or not, but I did remove the cam out of the 79' junk'd 650 with out issue... I wasn't sure if I needed to loosen or take the tension off of the  CAM Tensioner adjustment bolt/nut ?? and I wasn't sure if I needed to Rubber Band the Valves during the "Removal" ??
Just wanted to ask and make sure I was completely understanding the steps before tearing in..
Cheers Boyz !
« Last Edit: August 05, 2015, 09:14:17 AM by redrider736 »
Offline redrider736
Opppps.. Houston We have a issue?
« Reply #3 on: August 05, 2015, 05:36:15 PM »
Fingers crossed I didn't screw up too bad here ??
Well See the Pics..
Offline redrider736
« Reply #4 on: August 05, 2015, 05:39:49 PM »
Read all the great info above and read the manual going into this and feeling ok about it... Took my time had a few Capt&Coke(s;). I swear every bolt, screw, nut was finger tight from the PO.. The removal went great until the the Tac gear ??
Any help here?? what do I need to do at this point ??
« Last Edit: August 05, 2015, 05:52:32 PM by redrider736 »
Offline redrider736
« Reply #5 on: August 05, 2015, 06:23:58 PM »
Needle nose pliers, pull the remnant from the rice housing. That's the end of the cable snapped off in there. Beyond it is the actual gear itself that interlocks to the cam drive gear. Not a big problem really, and a good indication your tach probably didn't work, or was about to quit working.
ThX calj737 .... It may have been broke before I got my hands onto it ..? Who knows, just was worried it my have been a big deal... Broken bolts and such scare me..
« Last Edit: August 05, 2015, 06:46:46 PM by redrider736 »
Offline redrider736
« Reply #6 on: August 05, 2015, 07:12:27 PM »
Yep.... I just need to chill out... LOL.. That was easy! Install tomorrow... ThX !
« Last Edit: August 05, 2015, 07:14:11 PM by redrider736 »
Offline redrider736
NO Slack or TIME ! :(
« Reply #7 on: August 06, 2015, 07:58:46 PM »
Had a few spare minutes tonight to try to pull out my 550k Cam.....
Can't seem to get enough slack to get the Chain off/over of the Cam Sprocket ??  I backed off the Cam Tensioner Nut (Bottom), removed the 2 bolts from the Cam Sprocket....
Messed with it for over 45min with no luck....or Slack..
Any ideas or help ??
Offline flatlander
« Reply #8 on: August 06, 2015, 11:49:00 PM »
like this:
and this:
Offline redrider736
« Reply #9 on: August 07, 2015, 08:47:19 AM »
Wish it was that easy ... But there is NO SLACK to move anything..
The Sprocket is off the Cam, I have no movement to either Slip the chain over the Sprocket or move the Cam (Which I am not sure is possible)
« Last Edit: August 07, 2015, 09:14:42 AM by redrider736 »
Offline flatlander
« Reply #10 on: August 07, 2015, 11:21:39 PM »
which way did you turn the cam chain tensioner screw? to slacken the chain it's clockwise.
Offline redrider736
Success at last !
« Reply #11 on: August 10, 2015, 01:05:05 PM »
Took some fidle'n with, but in the end she finally came off ! Had to hold/push in the "Adjustment screw, and fully tighten down the "Adjustment nut" to create that small added slack needed.. (http://www.dotheton.com/forum/index.php?topic=67091.0 )
Thanks to dualitymike,  flatlander, and calj737 !!
Offline flatlander
« Reply #12 on: August 10, 2015, 02:58:12 PM »
congratulations, well done!
