SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Regulator / Rectifier which is the output wire? Red or Black?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Regulator / Rectifier which is the output wire? Red or Black? (Read 741 times)
Garage_guy_chris
Hot Shot
on:
August 14, 2015, 12:54:19 PM »
I have a quick question regarding the Regulator / Rectifier setup on the SOHC4's. Im doing a custom harness and wiring job and have upgraded to a solid state combo regulator/rectifier and I noticed the system has two power wires
-constant 12v red wire goes to rectifier stock
-switched 12v Black wire goes to regulator stock
I wanted to know which wire is outputting the charging power ?
It appears the red is the charging output and the black is just a power on / reference voltage but wanted to check before finishing things off
Logged
1971 Cb450 Cafe (on the road)
Bodi
Really Old Timer ...
Re: Regulator / Rectifier which is the output wire? Red or Black?
Reply #1 on:
August 15, 2015, 05:51:04 AM »
Yep. red goes directly to the battery and black gets +12V from the ignition switch. The field coil is powered from the black - if that's not switched power, it will drain your battery quickly when the motor isn't running.
Logged
Garage_guy_chris
Hot Shot
Reply #2 on:
August 15, 2015, 08:50:19 PM »
Thanks guys this clears up all my issues, hopefully i can finish the wiring now
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
