Author Topic: 76 oil tank on a 74 cb750  (Read 883 times)
Offline Greenie
« on: September 06, 2015, 01:51:40 PM »
I need to switch the oil tank on my 74 cb750.  I have one from a 76 to put on, but there one difference I'm not sure how to handle.  The 74 has a spout on it (circled in red) that the 76 doesn't have.  The spout is connected to the engine (also circled in red).  Has anyone else swapped these types of tanks out?  Can I just attach the hose to the engine and plug the other end?  Any thought's would be great.
Thanks,
Paul
« Last Edit: September 06, 2015, 01:54:05 PM by Greenie »
Offline Desert-SOHC
  • It's old
Re: 76 oil tank on a 74 cb750
« Reply #1 on: September 06, 2015, 01:59:49 PM »
There should be a hose on the 76 that does the same thing. That's for the expansion drain back to the engine.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Greenie
« Reply #2 on: September 06, 2015, 02:06:18 PM »
This is the 76 tank.  The diameter of the outlet on this tank is greater than the one on the engine.
Offline Old Scrambler
« Reply #3 on: September 06, 2015, 02:22:56 PM »
You will need the hose from the '76 tank...........or splice two hoses together. That bottom-vent tube on the K6 is a stand-pipe that ends near the top of the tank. Be sure its a snug fit..........or you will have oil on your tire ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Henning
« Reply #4 on: September 06, 2015, 02:28:05 PM »
You need that hose connecting the oil tank to the crankcase, so don't plug anything. It drains any oil back and I believe also equalizes crank and oil tank pressure. Use an adapter thing thing to go from one size hose to the other and you're good to go.
Maybe easier to source the correct tank? The hose size changed along the way; must have been between '74 and '76.
71 or thereabouts 750 K1 - this one should have been put down
Offline Greenie
« Reply #5 on: September 06, 2015, 02:31:36 PM »
Thanks guys.  I'll get the right tank.  Cheers.
Sent from my SM-G530W using Tapatalk
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: September 06, 2015, 03:34:41 PM »
That drain also helps to feed the auto chain oiler.  Just FYI
mystic_1
- John Augustus Shedd
Offline Greenie
« Reply #7 on: September 06, 2015, 04:19:01 PM »
Good to know.  I just looked at the 76 and the bit on the engine is the same, but a little bigger. The outlet on the tank is just different.   So yeah, can't plug anything.  Thanks again.
