Author Topic: BMW R100 Airhead  (Read 41187 times)
Offline simon#42
  • liverpool
Re: BMW R100 Airhead
« Reply #100 on: April 21, 2016, 12:18:18 PM »
that isn't telling you much scott , it only takes a second for the colour to change never mind 5 miles .
you don't know how it is on the main jet . best do a proper chop to be sure
Offline simon#42
  • liverpool
« Reply #101 on: April 22, 2016, 12:00:37 AM »
having spent what seems like years on the dyno with my bmw  i found that twin plugging does as cal said make the mixture leaner .
however as the revs rise the effect is not as noticeable and at high revs there seems to be no difference to a single plug set up .
Offline Scott S
« Reply #102 on: April 22, 2016, 03:59:42 AM »
 I'm hearing the same thing over on the Airheads forum and Facebook group. I'm just gonna keep riding it and enjoying it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #103 on: May 05, 2016, 11:08:26 AM »
 There might be a bit of an unbalance on the front wheel or something. I can feel.....something....not a wobble or even a vibration, really. Heck, it may just be "new bike" syndrome for all I know.
 Turns out that the front tire wasn't fully seated in the bead. I don't know what it was that made me look at it, but there's a tiny little ridge that runs around the circumference of the tire. I noticed that on one side it was behind the lip of the rim.
 Took it by the shop today and he seated/unseated it and sprayed it with WD40 and aired it up to about 80 PSI a couple of times and it eventually oozed out and seated. No big POP or anything, just finally took a seat.
 Runs smooth as butter at all speeds now!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #104 on: May 05, 2016, 11:55:35 AM »
 Also, my boot heel was touching the muffler on the LH side (and only certain boots). I found a pair of these heat sheilds on eBay for $15.98 shipped. The hose clamps were WAY too big, but I had some that worked.
 No more melted shoes on the exhaust.
'71 CB500 K0
'81 Yamaha XS650
« Reply #105 on: May 11, 2016, 10:07:00 PM »
While it isn't a R100 article, I thought you might enjoy...
10 days with a '75 BMW R90-6
http://www.motorcycleclassics.com/classic-german-motorcycles/ten-days-1975-bmw-r90-6.aspx
Offline Scott S
« Reply #106 on: June 25, 2016, 04:26:08 PM »
Spent a little time on the saddle bags recently. I ordered two replacement latches from MaxBMW; one to keep them closed and one for the latch that holds the bag to the rack.
 I thought that one of the rack latches was stretched out and busted because the P.O. kept forcing it on and off the holder rather than get a key for it. Turns out it was simply the wrong latch!
 That's probably why it allowed the LH bag to drop down on the muffler at some point.
 And in case you've forgotten, here are a couple of "before's" of the bags and busted latches.
 I repaired a couple of small hairline cracks, removed the decals, hit them with a Skotchbrite pad and some car wash and taped them up. After riveting in the new latches, of course.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #107 on: June 25, 2016, 04:31:06 PM »
 I wiped them down with Acetone and Preps-All and sprayed them with Krylon Dual Superbond paint. Turned out OK. I didn't do any "bodywork", so there are still some minor scuffs and scratches, and you can see a little "tiger stripe" in the paint under the right lighting. Still....much better than before. I used some Rok-Straps for a little extra security.
 (Oh...ignore the spot in the driveway....a friends car left that there a couple of days ago. That's not from the bike.)
« Last Edit: June 25, 2016, 04:34:02 PM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #108 on: June 25, 2016, 04:37:07 PM »
Here's something I think is neat....
 See the rear view?
 I used some 3M reflective tape that's black in the daylight but highly reflective at night.
 I'm pretty pleased with the way they turned out, especially with the repair costs vs. replacement costs. I put about 150 miles on the bike today, over some rough rural roads and at speeds of 80+ MPH on the interstate. Very solid now.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #109 on: June 25, 2016, 04:44:39 PM »
Tomorrow, I plan on checking the valve clearances (even though they only have about 1,000 miles on them since I did it last) and probably a carb sync.
I really didn't know what I was doing the first go 'round, and I have better TDC marks now (remember the flywheel being off by one bolt?). It's more of a peace if mind thing more than anything, but I do hear a little valve noise on the RH side.
It can be tough to find TDC by yourself on an Airhead! Trusty old straw to the rescue! The LH cylinder will be ready in the morning, once it's stone cold. Then I'll move it to the other side and watch it until I find my mark again.
'71 CB500 K0
'81 Yamaha XS650
Offline simon#42
  • liverpool
« Reply #110 on: June 26, 2016, 12:43:48 AM »
the rok straps are a very good idea  , i use these they are brilliant . the lock that holds the pannier to the frame is rubbish and will come undone on a bumpy road .
i found this out the hard way !
« Reply #111 on: June 26, 2016, 12:54:01 AM »
Bike looks really nice Scott. Nice job on the repairs.  Did you fix the bottom of the one where it had hit the exhaust?
Offline Scott S
« Reply #112 on: June 26, 2016, 03:25:19 AM »
 No.... Initially, I tried. I used my heat gun to try to soften it up and mash it flat(ter). When that had no effect, I tried smearing in some of the plastic weld stuff I bought, using it like Bondo, but it would have taken a massive amount. So, I just let it be. It's invisible once mounted on the bike.
'71 CB500 K0
'81 Yamaha XS650
« Reply #113 on: June 26, 2016, 03:47:46 AM »
Would roughing up the inside and putting a fiberglass patch over the area keep water out, or just silicone a patch of cloth in place... it has a hole in this area, right?
She is quite transformed from when you got her. A real looker now. If you sell her you should get a nice price for her. How do you like the handling and power? How many CCs? How are the brakes?
Is that the std BMW R100 fairing or an aftermarket. I have a friend in Sierra Vista, AZ who has an R90 he bought new.
David
« Last Edit: June 26, 2016, 03:57:02 AM by RAF122S »
Offline Scott S
« Reply #114 on: June 26, 2016, 04:47:11 AM »
 The place on the bag isn't melted through. And the P.O. seems to have done some sort of patch job on the inside...or, maybe that's his melted clothes!
 While I was skeptical, I can now "get" why people like these bikes. So, SO very different than our SOHC4's, or any other UJM for that matter. Some of the engineering seems to have been done "just because".
 It doesn't feel flickable at all, but the chicken strips on the tires tell a different story. A month or so ago I was riding with some friends on the Saluda Grade (nice curvy road near Hendersonville, NC) and my friend on a modern CB500 couldn't shake me. He commented later "It looked like you had that thing really leaned over", but it never felt that way to me.
 There's no "rip you off the seat" feeling of power, but it'll get you to 80 or 90 MPH right quick like. The brakes are OK. It has the triple discs/Brembo calipers. They're...adequate. The rear is known to suck and some people  convert back to drum but, like everything else on this bike, they get the job done.
 It's 1,000cc with dual plugged heads. The fairing is a genuine BMW S fairing that someone installed. The bars are K-model bars. I get 42-47 MPG with it and can go well over 200 miles before hitting reserve. In fact, I've never had to go to reserve. I think I've gone as far as 225 miles before filling up and never needed reserve.
 The riding position is sporty but all day comfortable. The R fairing/seating position actually has better wind protection than my Tiger Xc with a Givi Aero-Flo windshield.
 This bike doesn't excel at anything, but it does EVERYthing well. I can see why people become fanatics about them.
« Last Edit: June 26, 2016, 09:09:55 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
« Reply #115 on: June 26, 2016, 05:58:44 AM »
I like that Beemer and the work you did to it Scott,a very nice all-day touring bike that handles.
Offline Scott S
« Reply #116 on: June 26, 2016, 06:41:09 AM »
 Thanks!
 I spent two hours this morning checking and adjusting the valves and I should have just left well enough alone. I only did one intake and settled on a loose .004/tight .005.  Everything else was spot on and I probably should have left that one intake valve alone. Went with .004" intake and .008" exhaust.
 I'm told that noisy valves are happy valves on an Airhead. They tighten up with heat and over time, so loose is better than tight. Guess I just need to get used to the different sound from our Hondas.
 I might throw the sync gauges back on it again after the next ride. I think I have one throttle cable that keeps tightening up. I've tweaked the mixture screws and that one idle screw a couple of times trying to adjust the idle, so now my sync is probably off. Again....more for my peace of mind than anything.
« Last Edit: June 27, 2016, 04:57:35 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
« Reply #117 on: June 26, 2016, 08:53:55 PM »
Wonder if you have an air leak on the carb that is getting leaner. Check for it with some carb cleaner or other flammable spray at the gasket area of the carb to intake runner and at the head.  See if that might be doing it.  You may have a warp that getts worse as the metal expands & heats up.
Offline Scott S
« Reply #118 on: June 27, 2016, 03:09:05 AM »
I can't find a leak. The throttle cable on that side keeps tightening up and loosing freeplay. I straightened out a crook in the cable and did the carb sync yesteryear. Seems to be better.....for now.
'71 CB500 K0
'81 Yamaha XS650
Offline riverfever
« Reply #119 on: June 29, 2016, 08:03:19 PM »
Scott this really looks sharp. Great job. Love the color you used.
« Reply #120 on: June 30, 2016, 05:56:06 AM »
Thanks!
Good job mate, your bike looks awesome. Re: your rattly valves, I had the same problem on my first (1979) R100RS, and the culprit was badly worn rockers, that I had to have built up with hard welding and re-faced.
If I tried to set the clearances once I did it 10 times before I realised why it was rattling so much, and I don't believe that my valves rattled at all afterwards. My second R100RS (1980) had no such issues. Cheers, Terry. ;D
Offline Scott S
« Reply #121 on: June 30, 2016, 07:05:36 AM »
There's also a freeplay adjustment for the side to side (up and down?) movement of the rocker arm shafts. That can cause a noisy valve train too.
 I took a look at mine the other day and there were a couple that **maybe** could have used a little adjustment, but they were very, very close and, not having done it before, I decided to leave them well enough alone.
'71 CB500 K0
'81 Yamaha XS650
« Reply #122 on: June 30, 2016, 08:26:47 AM »
Hows your top-end gasket look? did you re-torque yet ?
Offline Scott S
« Reply #123 on: June 30, 2016, 10:37:27 AM »
 What do you mean by top end gasket?
 The first valve adjustment loosened the head stud nuts and the re torqued. This time I only torqued them, in three progressive steps.
'71 CB500 K0
'81 Yamaha XS650
« Reply #124 on: June 30, 2016, 12:10:18 PM »
I was just wondering if your topend/cyl. and head gaskets are still in good cond.
