Author Topic: where to obtain a geometric layout of a center main stand spring "hook" for 400F  (Read 570 times)
Offline Redline it
  • thread killer
Just a request for anyone that has a hook laying around that I could get actual dimensions from to cut one from scratch. I'd imagine tolerances aren't tiny. But a shot in dark could be a months long projects making multiple adjustments. I'll check to see if I have some thin titanium laying around. Maybe start with a stop sign piece first? yeah.
ref no. 238 part no. 50523-333-000
Thank you.
« Last Edit: September 23, 2015, 11:44:23 AM by Redline it »
Offline Redline it
  • thread killer
I'll run it through the morning rush hour and hopefully get a picture, with maybe an eye to eye as the crow flies shot measure, and either an outside or inside length shot, that should be excellent enough to get. I've never had one, for either 400F. I once went to a junk yard to look and ended up buying a semi truck trailer loaded with crashed (yet not severe) motorcycles, for $35.00. Next morning there was a pile of mostly honda 450s and 550s, 750s. There it was...and no center stand, nor hook. I had a pick a park in my backyard for 10yrs. Well thanks for the help.
Offline camelman
  • Man... Myth... Legend
^ might just be my favorite short story.  :)
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Redline it
  • thread killer
bam!! to me, that's better than the dimensions. thank you. Not many will believe the story is based on true facts. And they too could not imagine just what having that in a backyard, does to a bike rider.
Offline Redline it
  • thread killer
So the latest on a home made center stand spring boomerang link. I pick up a load of junk from ebay, it had a worn out link. I looked around and there was 2 plates of approx 1/8". I've seen them around years ago, and I knew they were good material. Traced it out and thought I'd cut it close with an oxy/acet torch, right? That didn't work as planned. Bright flashes of sparks and thin puddles was all the big tip could do. And because the garage is so cluttered with no clearance room I read up on it, and found out I might have some dangerous titanium on my hands so, thought I'd try again, no luck. Spent a day grinding this thing out and drilling, tougher than I'd ever seen thin sheet before. Thanks to all and  anyone that was planning on helping out with a dimension sketch.
