I tore down the valve cover/rocker assembly on a 1978 CB550 for inspection and noticed that the shafts have some scoring marks under the rockers. The cover is a late model with the locked shafts. I can feel the scoring with my finger and am concerned that the shafts might be toast. Also, if the shafts are scored, shouldn't the rockers be replaced too?
im not rebuilding the engine at the moment, just cleaning it up and running as is. It has about 19k on it and sat since 1986. I got it running a month ago. Should I be concerned about the wear or will it be fine for a while?
If I need new shafts and rockers, does anyone have a decent set?
