Author Topic: Head porting without flow bench: waisting time & money?  (Read 11877 times)
Offline crazypj
  • I'm brill, me
Re: Head porting without flow bench: waisting time & money?
« Reply #25 on: November 13, 2006, 11:16:42 AM »
Really interesting thread, esp. since I'm going to try this on my 350f soon. A couple questions- Would it work to leave more material on the downstream side of the valve guide, ground into more of a boat tail shape to smooth airflow past the guide, or are you just better off without it?
Yes and no.
It can smooth flow but also act as a flow diverter and prevent (or enhance) the direction of main gas stream.
http://en.wikipedia.org/wiki/Cylinder_head_porting#Wave_Dynamics
http://www.se-r.net/faq/articles/head.tech.html
PJ
« Last Edit: November 13, 2006, 11:18:57 AM by crazypj »
Offline maksuttt
« Reply #26 on: November 13, 2006, 12:07:15 PM »
Maksuttt, did you do anything with the combustion chamber around the intake valves, or leave it be?
I have 1975 F model and chambers have almost nothing to improve (if compare to older models). I just removed imperfections without removing any real material. Gonna polish it in nearest future.
BTW, iteresting link!!! Thanks, crazypj!
CB-750F 1975
My gallery is here
My blog is here
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #27 on: November 13, 2006, 01:38:46 PM »
Just curious, what does this polishing garner in the way of performance and how to you measure it?
Online MRieck
« Reply #28 on: November 13, 2006, 02:32:49 PM »
Helps retain heat. Higher exhaust gas temps(slighty).
Offline maksuttt
« Reply #29 on: November 13, 2006, 03:42:41 PM »
Also, less carbon buildup... I like polished piston domes too ;D
CB-750F 1975
My gallery is here
My blog is here
Offline sparty
  • I just play one on TV
  • My engine is 100% stock... wink.
    • Gallery
« Reply #30 on: November 14, 2006, 05:37:26 AM »
Does anyone have a before picture of their ports before the surgery?
Sparty
1972 CB750 K2 Cafe' Style
GO AWAY SNOW AND COLD!  Can you see the Hot Rod wants to run...
“That's thirty minutes away. I'll be there in ten.”
Online MRieck
« Reply #31 on: November 14, 2006, 05:50:22 AM »
Sparty
I have posted them before...a while ago. I'll see if I still have them.
Online MRieck
« Reply #32 on: November 14, 2006, 05:55:53 AM »
 These are uncleaned but you can get an idea.   http://www.sohc4.us/forums/index.php?topic=6795.0
