Author Topic: 1969 cb750 carbs  (Read 1774 times)
Offline goldarrow
  • one day, i'll be an
1969 cb750 carbs
« on: November 14, 2015, 01:13:01 PM »
Bought this off feebay, looking for casting numbers but they are not there??? Aren't these suppose to have carbs model casting on them?
CB550 K0
Offline harisuluv
Re: 1969 cb750 carbs
« Reply #1 on: November 14, 2015, 01:59:19 PM »
There is no casting numbers on k0 carbs.  The only number is on the backplate which is B750A.
Offline goldarrow
« Reply #2 on: November 14, 2015, 02:03:02 PM »
Gonna keep looking
CB550 K0
Offline goldarrow
« Reply #3 on: November 14, 2015, 02:06:50 PM »
Found it. B750A stamped on the mounting backplate as harisuluv mentioned, no other castings on the carbs bodies.
Slides are stuck on all 4, going to cook them in boiler
CB550 K0
« Reply #4 on: November 15, 2015, 09:00:02 PM »
 My PO just cranked the throttle until it broke. L0L! good luck, they're worth the effort.
Offline goldarrow
« Reply #5 on: November 17, 2015, 10:50:34 PM »
Got the slides freed up using hot water ;)
CB550 K0
« Reply #6 on: November 18, 2015, 05:40:49 AM »
You should send them to Nils for vapor blasting.
Offline goldarrow
« Reply #7 on: November 24, 2015, 07:58:01 PM »
Would really love to if I were to build a show bike...
CB550 K0
Offline goldarrow
1969 cb750 carbs
« Reply #8 on: November 24, 2015, 07:59:48 PM »
Can someone verify or confirm that stock Main jets on these K0 carbs are 130? At least that's what I remembered from reading
CB550 K0
« Reply #9 on: November 24, 2015, 08:04:13 PM »
 I bet 120,s
Offline goldarrow
« Reply #10 on: November 24, 2015, 08:21:46 PM »
CB550 K0
Offline kmb69
« Reply #11 on: November 24, 2015, 08:26:48 PM »
Frank is correct, 120's.
Offline goldarrow
« Reply #12 on: November 24, 2015, 08:30:02 PM »
This carbs set that I just bought came with 115, not surprise as they could have been changed, but only 3 main jets, missing one.  So I looked up in the local Honda parts fiche online and it shows 140, so I'm confused???
CB550 K0
Offline harisuluv
« Reply #13 on: November 24, 2015, 08:46:50 PM »
Sometimes the Honda parts fiche will show some oversized jet sizes.  Same as how there might oversized Pistons. You want a 120 most likely, although I have seen 115 also. Hondaman has cited some changes during production if you are really curious. 115 will work or you can get 120s.
Offline kmb69
« Reply #14 on: November 24, 2015, 08:59:42 PM »
