Author Topic: Clutch Lifter Rod (1971 K0 500 Four)  (Read 1376 times)
Offline paulbaker1954
  • I 'll just be 5 minutes dear!!
« on: December 09, 2015, 05:34:08 AM »
In my engine tear-down i discovered the clutch  lifter rod is in 2 pieces. Looking at the parts list it looks as if it should be a single piece. Can anyone confirm this?
If it is in fact a single rod I can't understand how this could have sheared about 3 inches from the left hand case end but hey stranger things have probably happened.
This bike was WELL seized ( I still cant get the gudgeon pins out of the pistons despite liberal heat and a fly press. I am scrapping the pistons anyway so probably just hacksaw or smash the pistons with a big hammer  ;D ;D ;D. As long as I can save the rods I am OK.
If you think there's light at the end of the tunnel it's usually another train !!
2014 Triumphy Trophy 1200
1971 Honda CB500 Four K0
Offline sammermpc
Re: Clutch Lifter Rod (1971 K0 500 Four)
« Reply #1 on: December 09, 2015, 07:11:29 AM »
Yes, the lifter rod should be a single piece. It is a common issue in the CB500s—I'm not sure the cause, but I've read a loose chain can do it. Not sure how that'd work.
They are difficult to find online, these days, though David Silver sometimes has replacements, and I believe the CB450 uses a similar rod, and can function as a drop-in replacement.
1972 CB500, 1979 CB750F SS (dohc), 1982 Yamaha Maxim XS400
Offline fodzilla
« Reply #2 on: December 12, 2015, 03:27:50 AM »
Had the same issue with mine.  Couldn't find one online at the time so just put both pieces back in the bolted it up until they are available again.
CB500 Four K1 '75
Offline Bailgang
  • Scott
  • Indiana
« Reply #3 on: December 12, 2015, 04:39:20 AM »
The pushrod is real close to the front drive sprocket so too much slack in the chain can allow the chain to smack the pushrod, it can also play hell with the clutch pushrod actuator as well. I had a 500 with both a broken pushrod and broken actuator, finding another actuator was the hard part for me but I made my own pushrod using 2 pushrods from spare parts I had from a Pontiac V8 which just happened to be the right diameter. It took 2 of them cut and spliced together to get the length I needed and it worked perfectly. This was possible only because I have my own welder and lathe.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
