Author Topic: 400F tranny...  (Read 1888 times)
Offline Denver_Larry
400F tranny...
« on: January 25, 2016, 09:16:02 PM »
I'll be opening up the cases on my 350F anyways, and 400 gear sets seem plentiful and cheap in eBay.  Is this a drop-in swap, or am I in for more pain than that?
2005 RC51
1973 CB350F...project
Offline MoMo
  • Ride like you're invisible
Re: 400F tranny...
« Reply #1 on: January 26, 2016, 03:19:19 AM »
not sure,  350 was a 5 speed and 400 six.  Seems unlikely
Re: 400F tranny...
« Reply #2 on: January 26, 2016, 05:03:08 AM »
If it was a direct "drop-in" it would have been done already. To know for sure have a 400F complete gearbox (including drum, shift mechanism parts) to compare when your 350F cases are open. From experience I expect your issues may be differences in bearings and very likely shift drum and shift mechanism components and how they attach.
Good luck
Online Don R
Re: 400F tranny...
« Reply #3 on: January 26, 2016, 08:14:58 AM »
 I seem to remember something about the cases being different.
Offline carnivorous chicken
Re: 400F tranny...
« Reply #4 on: January 26, 2016, 08:26:24 AM »
Nope, not a direct swap...
Offline grcamna2
Re: 400F tranny...
« Reply #5 on: January 26, 2016, 08:26:46 AM »
I hope it fits;they should have put a six in the CB350F from the factory.
I think a couple members here  could measure their trans. mainshaft & countershaft length from where the bearings sit tight against each end for the 400F & 350F;I imagine that would be the determining factor as to whether they would swap.The other thing you probably would have to do is get the Complete trans. from someone including all the shims,etc. You could do a parts-check between the two bikes on an online fiche to see if the bearings,etc. are the same,that's where I'd start.
75' CB400F/'bunch o' parts'
Offline MoMo
Re: 400F tranny...
« Reply #6 on: January 26, 2016, 09:32:05 AM »
I have a spare 400 four trans complete.(most everything I have is spare as I rarely use any of it-and it all is for sale).Larry
Re: 400F tranny...
« Reply #7 on: January 26, 2016, 05:17:03 PM »
Some machining can make it fit in the cases. It's to get a look behind the clutch basket, shift mechanism, mainshaft length, clutch. No way it's an easy mod BUT where there's a will!! Been there done that.
Re: 400F tranny...
« Reply #8 on: January 27, 2016, 09:21:42 AM »
Thanks, I may save that as a future upgrade then... Or just find a complete 400F engine to rebuild...
2005 RC51
Offline Flyin900
Re: 400F tranny...
« Reply #9 on: January 27, 2016, 09:02:40 PM »
I would question the ability of the 350's tiny output to be able to deal with a 6th gear too.
Honda listed the HP in the low 30's and there is very minimal torque, so a extra gear on that motor would be iffy at best.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline grcamna2
Re: 400F tranny...
« Reply #10 on: January 27, 2016, 10:10:41 PM »
I think a 400F motor in a CB350F is a Great upgrade for it !
Re: 400F tranny...
« Reply #11 on: January 28, 2016, 04:34:56 AM »
Flyin900, more tighter gear selections helps small engines, instead of wider spaced, fewer gear option gearboxes.
One example...Honda's own RC112 (50cc twin) with a 9 spd box. OR Suzuki's RK67 with a 14spd.  ;D
Offline grcamna2
Re: 400F tranny...
« Reply #12 on: January 28, 2016, 06:58:15 AM »
What's "Flyin900"  Brent?
Re: 400F tranny...
« Reply #13 on: January 28, 2016, 07:48:20 AM »
That's the fellow's handle 3 posts up!
Offline grcamna2
Re: 400F tranny...
« Reply #14 on: January 28, 2016, 07:55:32 AM »
oops  :o ::) it comes from not wanting to look backward much,sorry
Offline camelman
  • Man... Myth... Legend
Re: 400F tranny...
« Reply #15 on: January 29, 2016, 10:26:06 AM »
While you have your trans apart, check the bushings on first gear. They often wear out and create difficulty shifting. You can quickly check by feeling for wobble of the gear on the shaft. It's an easy fix for a machinist to press out the worn bushing and replace with a new one. The machinist will have to make the new bushing.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Re: 400F tranny...
« Reply #16 on: January 29, 2016, 01:50:14 PM »
Thanks for the tip Camel..
2005 RC51
