Author Topic: Starter button  (Read 721 times)
Offline beemerbum
Starter button
« on: February 10, 2016, 05:03:52 PM »
After refurbishing this barn find for some time, I just noticed that it is missing a starter button. Buy a whole new right side switch body or is there a cheap (I hope) and easy fix? The wiring runs inside the bars and I don't look forward to pulling them out.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
Re: Starter button
« Reply #1 on: February 10, 2016, 05:15:42 PM »
My starter button disintegrated, but the rest of the switch was fine. I shopped eBay for a similar era switch, figuring the actual button assembly would be the same and I was right. Cannabalized the eBay switch to remove the button assembly and grafted it into my original switch and it's been fine ever since.
Offline beemerbum
Re: Starter button
« Reply #2 on: February 10, 2016, 05:28:35 PM »
4 into 1 sells a button and spring. The button appears to have a little brass probe. Both are genuine Honda parts Would these suffice?
Offline mystic_1
  • 1970 CB750K
Re: Starter button
« Reply #3 on: February 10, 2016, 05:39:31 PM »
That depends on what's missing from yours.  Inside the housing is a little bit of circuit board with a contact on it, plus a little brass piece that the spring pushes against.  If you've got those then the spring and button itself is all you would need.
Source:  How-to rebuilt your starter/kill/light switch (Heavy pictures!)
mystic_1
- John Augustus Shedd
Re: Starter button
« Reply #4 on: February 10, 2016, 05:45:56 PM »
Which bike?
Offline beemerbum
Re: Starter button
« Reply #5 on: February 11, 2016, 08:27:22 AM »
CB 750 K1 (1971)
