Author Topic: 1971 cb750 wheel hubs...?  (Read 925 times)
Offline la ca fe
« on: February 11, 2016, 07:53:05 AM »
Is there a difference between the front and rear wheel hubs form a 1971 to 1973 cb750 ?
I have a 1971 cb750 that needs wheels and I have a set off of a 1973. I want the bike to be stock and am wondering if there is a difference?
Your help is appreciated.
1976 cb750k
1976 cb750f
1975 cb750f
1970 cb750
1977 xs750
Offline wowbagger
  • Not much of an
Re: 1971 cb750 wheel hubs...?
« Reply #1 on: February 11, 2016, 08:30:59 AM »
According to the parts fiche for the hubs, there are 3 different part numbers for these two bikes:
1971 CB750 up to serial #1073285 - Part #42601-300-020
1971 CB750 from serial #1073286 - Part #42601-300-030
1973 CB750 - Part #42601-300-030
That said, the 1973 wheels should work just fine on your 1971. They did not change the size, offsets or bearing sizes between those two bikes as far as I know.
« Reply #2 on: February 11, 2016, 12:38:21 PM »
The early 750 K0 bikes had no shoulder on the right side of the hub for a 2nd disc brake, and the holes for the spokes were a bit smaller. After that, they were the same until the F0 bike appeared.
