Author Topic: Removing pilot jets  (Read 880 times)
Offline cuz
Removing pilot jets
« on: February 26, 2016, 07:25:52 PM »
Does anyone have some advice on pulling the pilot jets on the PD carbs for my cb750k7?   I tried pulling on one of them with a pair of pliers but didn't get to far.   I marked it up with the pliers and didn't want to make it any worse so stopped trying.   I have rebuilt and cleaned the rest of the components but from reading on the forum I had better check the pilot jets to finish everything correctly.
Offline danyo
Re: Removing pilot jets
« Reply #1 on: February 26, 2016, 07:59:28 PM »
Heat will help, and use something to protect brass i.e. rubber hose.
Sent from my SM-N900T using Tapatalk
Offline theslayedsaint
« Reply #2 on: February 26, 2016, 08:12:03 PM »
weird guessing that model doesn't screw out? i would stay away from heating something that has had lots and lots of gas running through it... you could always cut a line in the top and turn it freeing it up. thats if your replacing them.
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
Offline Mr Freeze
« Reply #3 on: February 26, 2016, 11:54:23 PM »
Get a small piece of leather and wrap it over the jet, then use your pliers and give them a gentle circular rocking motion and they'll come right out.
Offline brewsky
« Reply #4 on: February 27, 2016, 01:57:47 AM »
Slip a short piece of reinforced fuel line over the jet and grab with vice grips.
Pull straight off, twisting if necessary..do not bend sideways.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
